got my motor and trans in last night... and put some shims on the motor mounts to get my headers to clear and my e21 booster to clear. and it looks good so far. i am using the 260 trans, drive shaft and diff, from a 90 325is. so i have the diff in already, just put the drive shaft in and it is not straight when the csb is bolted in. but then i hold the shaft up it goes straight. so do i just flip my csb around? i'm not sure if this is common with the m50/g260 set up i know it is needed for other set up's......
drive shaft not straight with g260/m50...
91 e30 318is M50 SOLD
http://www.r3vlimited.com/board/showthread.php?t=149570
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Tags: None -
just flipped the csb looks good now...91 e30 318is M50 SOLD
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370 -
no I didn't bolt it until I had it all straight. I just got it all lined up and just made a brace for the trans. ill bolt it in tomorrow when the paint drys and see how it looks.91 e30 318is M50 SOLD
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Comment
i have the tranny on a jack and i made a trans mount to go on it after it all looked good. see what happens tomorrow when i get the trans mount on....91 e30 318is M50 SOLD
92 325 vert project
bolted in the trans mount i made and it all seems to be good.91 e30 318is M50 SOLD
92 325 vert project
