did i swap the right temp sensor?
  • platanos
    • Apr 2008
    • 459
    Which sensor is needed for an s52 swap?
    ~Fernando
    • 2002maniac
      • 4260
      Originally posted by 1991 e30 bmw 318is
      I did not try that. I'm just going to get a real temp gauge....
      why not just fix it? There's nothing wrong with the stock guage.
      • jakeb
        • 1909
        Yeah the stock gauge is good.....it works the same way as an after market gauge other than it doesn't have any numbers. needle moves to the right...coolant = hotter, needle to the left coolant = colder.
        Have you tested the wiring like I suggested? Have you even let the car run all that long with open headers? They do take awhile to warm up, expecially when idling.
        Man now I understand r3v.....
        Don't be a bad PO
        www.classicdaily.net
        1970 m42 swapped 2002
        1985 LS1/T56 Swapped e28 (557e)
        www.blunttech.com - For all your parts needs
        Follow me on Instagram for constant build updates @classicdaily
        https://www.facebook.com/ClassicDailyLLC
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          Try the m20 sensor and see what happens. It should be a single prong sensor, don't worry about the fact that the plug is for a two prong it will still function.
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • 1991 e30 bmw 318is
            • 523
            Originally posted by jakeb
            There are two sensors....one for the dme and one for the gauge. Do you have the wiring right? You might be able to ground the wire going to the gauge and it should peg to full hot... Maybe someone can confirm this. If so then run a wire from the plug that goes to that temp sensor ground it and turn the key...the temp gauge should peg, if it doesn't you have a wiring issue.
            Don't just get a after market gauge....fix the real problem
            ill try this as soon as it's nicer out so i can get the car out side to let it run. so I put the sensor from my m42 back in, its the one in the front of the car right...... Then ground the wire that plugs into the sensor, there are 2 wires there so do I ground one of them? then what with the other?
            if i can get it working i guess it will save me $ I just didn't know how accurate it was going to be. .
            Thanks Jeremy
            91 e30 318is M50 SOLD
            http://www.r3vlimited.com/board/showthread.php?t=149570
            92 325 vert project
            http://www.r3vlimited.com/board/showthread.php?t=341370
            • Fidhle007
              • Oct 2005
              • 7209
              It's very accurate. Seriously, just fix it.
                • 523
                ya i well, as soon as i figure out how...
                92 325 vert project
                • jakeb
                  • 1909
                  Or check for continuity from the sensor plug to your c101/x20 plug, make sure you have a connection there. Do you know how to check for that? can use a MM with either a beep check or resistance setting
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    My guess is you haven't used the right sensor yet. It should be a single-prong with brown plastic.
                    • matt
                      • 3731
                      And you may not have it wired correctly.
                      And in your picture, you seem to have the plugs plugged into the wrong sensors.
                      The wire with the blue tape goes on the blue sensor, this is for your DME.
                      The other wire goes on the brown e30 sensor with only one pin. This pin needs to be connected to the coolant temp wire at your c101.
                        • 523
                        humm.. i know i never mixed them up, if they are it was like that because i never had both off at the same time. Too be sure i did not mix them up. going to the junk yard now to get the sensor off my old parts car....
                        92 325 vert project
                          • 523
                          ok i just got the right one. brown single prong from an m20, so it goes in the front right? and i just use the stock e36 plug? and re thread it to make it fit?
                          92 325 vert project
                            • 523
                            here are some pics of what i just did. i found the real wire for the gauge, by grounding it. it was on the black sensor on the back side. so the wire labeled with blue is going to the front sensor blue one also witch is the one i swapped the sensor in, from my m42. so that was the problem. so if i pull the black sensor out and put that one from my m42 back it there will it work? I'm still not sure that i have the right one from my m42 because it is a 2 prong. but it has the same threads so it fits right in, it would be nice if i just had to put it in the right place. here are pics.......
                            this made the tamp gauge go to hot...
                            and this is the m20 sensor....
                            and the m42 sensor i have....
                            m20 left ..... m42 right....
                            so is the problem just that I put the m42 sensor in the wrong spot? because i know people do use them from the m42.. if this is the wright one it would be nice because if I'm stuck using the m20 sensor then i need to make it fit...... or do i need a different m42 sensor?
                            92 325 vert project
                            • Fidhle007
                              • Oct 2005
                              • 7209
                              I'm pretty sure that's an M42 ECU temp sensor, not the one for your gauge. You need a blue, double-prong one for the ECU (preferably for an E36) and then the brown M20 one you have will go to the gauge plug as is, even though it's wired for two.
                                • 523
                                that's what i thought. so i need to rethread it...
                                92 325 vert project
