Need some help with the Master and Booster
  • SA E30
    • 1248
    Hey guys.
    Ok, so here is what I've got a S50b30Euro.
    What I'm thinking of doing is keeping the stock booster, and notching the plenum (which I know has been done in the past), but I want to know is if there is a 25mm MC that will bolt up to this Booster? (also part no's would be highly helpful)
    Reason I ask this is my understanding is that I would have to use a iX Booster, and e34 M5 master (which seems like this master doesn't bolt right up to the std e30 booster)
    Also we didn't get the iX over here so that booster is a no go, and the e21 just as scarce.
  • DaveSmed
    • Apr 2007
    • 1407
    Your car RHD or LHD?
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • 2002maniac
      • 4260
      Use the stock booster with a 25mm Master Cylinder from a 7 series. Search "25mm master" to find the part number.
      Since your car is RHD you dont have to notch the intake manifold. (Unless you are doing a LHD swap)
      • xLegendOZWest
        • Jan 2009
        • 406
        what booster would i run on a LHD cabrio with an m50 with what master?
        Live Fast. Drive Faster.
        "Nitrous is like a hot girl with an STD... :)
        You wanna hit it, but your afraid of the consequences :(
