M5x, S5x Spa turbo Manifold? anyone
  • lifeiskaos
    • 1709
    nice find! but yeah i agree it could have been done better
    • flyboyx
      • 8371
      Originally posted by lifeiskaos
      only because it will give the best angle for a gravity feed... i agree, it's better to put the return higher on the pan, but there are only a few inches from the turbo to the top of the oil pan, and you have to run a line forward in the engine bay, unlike e36 guys. a bung on the top of an e34 pan will give you an almost horizonal line...
      im not here to argue which is better, it was just an idea that would be cheap and would most likely perform well, given the line doesnt come off :D
      of course it makes sense to get the return oil out of the turbo and into the pan as quickly as possible, but keep in mind the oil going into the turbo is under pressure. once the return line fills with oil as it eventually will in the photos, the pump pressure will force the return oil back to the pan anyway. i don't see a problem. an after market turbo timer might be a good idea to avoid coking after shutdown.
      Gigitty Gigitty!!!!
      • matt
        • 3731
        The oil going into the turbo is very low pressure and the return line should have NO pressure. If you have pressure in your return line, you will be blowing clouds of black smoke out your tailpipe.
        Originally posted by Mako18
        Here is a pic of the pan and the drain location in the oil pan.
        That's exactly where I would put it. Keep in mind, the SPA manifold mounts the turbo slightly higher and closer to the block than the Turbonetics, so the angle will be better.
        • Mako18
          • Jul 2006
          • 688
          Just what I wanted to hear. Thanks
          • Mako18
            • Jul 2006
            • 688
            Figured we could get a list going while we are waiting on a price? I guess I will start.
            1. Mako18
            2.
            • lifeiskaos
              • 1709
              1. Mako18
              2.lifeiskaos
              • golde30
                • 11464
                Matt, i am would be very interested to see a turbo kit using this manifold for 24v e30's... make it happen!
                IG: @Baye30
                • matt
                  • 3731
                  Do you want to send me your car and let me do one to build the pipe jigs and base the kit off of? I don't own a DOHC e30 anymore. I have a few local people who have flapped their gums about having us do a kit, but nobody put their money where their mouth is.
                  I'll be happy to run this GB and give a decent discount if I can. The more the merrier, if you know what I mean. I'll give a price when we get a good idea for how many people are interested.
                  • e30s52
                    • Oct 2007
                    • 5235
                    I would be intrested in one depending on the price.
                    www.gutenparts.com
                    • siexyy55
                      • 69
                      Originally posted by e30s52
                      i would be intrested in one depending on the price.
                      +1
                      • matt
                        • 3731
                        **Updated**
                        OK, it takes 5 people to get these prices.
                        SPA manifold only (no WG pipe) - $500 (16% off)
                        TRM motor mount - $100 (33% off)
                        If you guys want any other parts, let me know, I will see what I can do.
                        Thanks,
                        Matt
                        • golde30
                          • 11464
                          sooo, do i get a free turbo kit installed since my car is being used as the template? hehe
                          IG: @Baye30
                          • matt
                            • 3731
                            Nope, but you get the first kit, installed and tuned, for a reasonable price.
                            I lowered the price on the manifold in the post above... Check it out. $150 off if you buy the combo. :)
                            • lifeiskaos
                              • 1709
                              how about if there are more than 5 people? thats hardly less than it is on ebay no offense...
                              • matt
                                • 3731
                                The guy on ebay is selling them for the old price. Prices have gone up since then. Sorry.
                                If you get 5 people, I will see what I can do. This is cutting it pretty thin as it is.
