Links to the Info
  • OrganicMechanic
    • Jan 2008
    • 1719
    Links to the Info
    Serpentine belt/power steeringc101 and x20 wire diagram (e30 M50 adapter)
    Vacuum line
    Please add info and links that are useful.
    join the E30 Cabrio owners gruppe
    click here for details
  • SamE30e
    • Sep 2007
    • 4319
    http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
    1985 325e 2.8 Turbo VEMS
    • etxxz
      • Feb 2006
      • 2085
      i predict this thread = disaster.
      No more e30s for me.
      88 black BMW OBDII 332is dedicated track [sold]
      88 BMW OBDII bronzit 332is [RIP 03/08]
      91 BMW 325i [sold]
      86 Corolla 'Ae86' HB 20v trd [sold]
      http://youtube.com/watch?v=pTj7Hn9v5Rs
      • rThor432
        • Feb 2007
        • 3907
        Why is there a link to serpentine belt routing?
        Some helpful info-- I think that you have to use the E34 525i oil pan and OBD 2 swaps arent as popular as OBD 1 swaps.
        • etxxz
          • Feb 2006
          • 2085
          You are right. Here's that link
          The comprehensive DOHC engine swap thread
          91 BMW 325i [sold]
          • rThor432
            • Feb 2007
            • 3907
            ^^I almost posted that link. But I felt like I was being too helpful, and I wanted to give others a chance to post up!
            • gazellebeigem3
              • Jun 2005
              • 3712
              • OrganicMechanic
                • Jan 2008
                • 1719
                trying to condense the 1000+post
                • etxxz
                  • Feb 2006
                  • 2085
                  many have tried. none have made it back alive..
                  91 BMW 325i [sold]
                  • OrganicMechanic
                    • Jan 2008
                    • 1719
                    odb II adapter cord
                    • OrganicMechanic
                      • Jan 2008
                      • 1719
                      wiring chart
                      Originally posted by The Big Read
                      Okay, the fuel pump problem is easy. AKG have got the pins wrong on their chart.
                      They have got E30 pin 6 going to E36 pin 13. You should have E30 pin 13 going to E36 pin 13.
                      E36 pin 13 is a 12v signal coming from the E36 fuel pump relay. This passes through pin 13, and needs to go to E30 fuse 11, and then off down to the pump.
                      AKG have got a 12v signal coming from the E36 fuel pump relay and connecting to E30 pin 6. This is a 12v signal from fuse 9 that would normally drive the O2 sensor relay. They basically have 12v connecting to 12v coming the other way.
                      I also noticed they don't have any connection for the Rev counter. You need to have E30 pin 9 connected to E36 pin 20.
                      You also need to connect E30 pin 14 to E36 pin 14. This is the road speed signal into the DME. Without this signal, you will not reach maximum RPM.
                      If you want the Unloader relay circuit to operate correctly, you also need to connect E30 pin 15 to E36 pin 15.
                      Unfortunately, I can't see any of the above connections stopping it from firing (assuming you give the fuel pump some power).
                      It's got to be worth connecting as above, and have another go though.
                      Ian.
                      • OrganicMechanic
                        • Jan 2008
                        • 1719
                        HFM Clocking
                        • Rolla1990
                          • 199
                          I'm just waiting to get Rick Rolled by one of these links...
                          Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
                          • OrganicMechanic
                            • Jan 2008
                            • 1719
                            this thread is strictly business
                            I just drove mine after getting my bugs worked out. I isolated my fuel pump realy with a another relay to isolate any back feed and it has fixed it. I used the wiring chart posted here with the updates. No issues with drive ability--acts natural. For those who are still having issues with fuel pump and O2--use the e30 pin 13 to trigger relay-and positive 12v ignition on to relay to power e36 pin 13. I will get th exact pins in the morning as far as 30--85--86--87 and what goes where.
                            • OrganicMechanic
                              • Jan 2008
                              • 1719
                              electrical service manuals
