So I'm starting to experience a lot of stuttering, hesitations, and backfiring. It ranges from idle, to WOT, to any time randomly going at a constant pace for example.. i'm driving 45 mph and all the power just cuts off and then comes back, or vice versa, i'm driving 45 at like 3k rpm then it will spike to like 3600 rpm like i kinda pressed the gas. At idle sometimes it will go up to 1600 then to like 800 then to 1600, 1500 1400 1300 1200 1100 rpms and just keep continuing that cycle. I checked for vac leaks but couldn't locate any, i have a fealing it's either the oxygen sensor or the TPS (throttle posistioning sensor). Any ideas guys? Other then that the car seems to run great, but it gets annoying due to how jerky it feels when it cuts of and then GOES.
thanks,
-Abe.
edit: this went away, the car drove fine for a few days and then it just died on me while i was on the highway, (thanks e30..).
Current problem/s:
Check engine light does not work (Wiring adapter)?
Diagnostics plug does not work (Wiring adapter)?
car does not start.
I've changed the o2 sensor and the CPS, no luck.
thanks,
-Abe.
Current problem/s:
car does not start.
tho.
