i was wondering around my local pick a part and came across a 635i. i know the hydraulic brake system is more complicated than simply using a vacuum booster, but i see advantages. i wonder why almost no one uses this system on their e30s? anyway, i spent 40 bucks on the entire thing, so i figured at least i will have the over size master cylinder out of the deal if i never use any of it.
there are a few barriers to using this syst in an e30. the hoses from the 6 series are not compatible, but i have parts cars up the ying. i am hoping that i can use some of those. the problem is the pressure lines. the returns are no big deal. they can all be replaced with new hoses on the hose barbs.
locating the componets could be a slight problem. the acumulator( the black round bulb thing) could be located under the master cylinder but a bracket would need to be welded to the inner fender to hold it in position.
the resevior is about twice as long as the standard one. it would fit fine on the motor arm bracket. i don't know if it can be mounted that low, since the booster would be above this location.
i have not read much about this swap, but there are a few negatives on the forums. the biggest being that it is complicated to hook up. to this i say it would just be a matter of coming up with pressure hoses that will work.
i think the hydro brakes will be more powerful than the e21 booster that everyone uses. i have read to the effect that you can loose feel or lock the brakes up easier with this syst. i have abs, so i can't imagine wheel lock being an issue.
here is the size difference between the e30 mc and the e24.
here is a comparison of the end that goes through the firewall. the hydro is about three eights inch shorter, but i can take that out with the clevis adjustment.
i am going to be running the setup on the right below. i'm not confident my e21 booster will handle thes adequately.
