No/Weak Power?
  • FredK
    • 14762
    Yeah, the CEL does not illuminate with a VSS code.
    • evil_twin
      • Nov 2007
      • 2965
      Alright. Now with this being said... Where do I check the wiring? I didn't do my wiring for my swap, the guy I bought the motor from did it.
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • FredK
        • 14762
        If you have a wiring adapter, check to see that pin 14 on the x20 matches up with pin 14 on the C101.
        Check instrument cluster connector C2 pin 10 (BU/YL) with C101 pin 14. If that checks out, try to borrow an instrument cluster from someone. Sometimes clusters can go bad, and the injection electronics uses the speed output signal at C2 pin 10 on late model cars.
        • evil_twin
          • Nov 2007
          • 2965
          I ran the codes today, and I have an o2 sensor code, and a knock sensor code.
          Delta Auto Care
          Herndon, VA
          703.435.1375
          • sharksforthecup
            • Aug 2007
            • 246
            Originally posted by e30polak
            Was it the solenoid or the actual unit?
            Pretty sure it wasn't the solenoid since it was fine when it wasn't under load. (reving out of gear)
            Then when it was in gear it would totally crap out right at 3k rpm's. I just figured it was the seals even though when the shop tested the unit with air pressure it actuated just as it was supposed to.
            • evil_twin
              • Nov 2007
              • 2965
              So anybody know why it feels like im not making any power/torque?
              Delta Auto Care
              Herndon, VA
              703.435.1375
              • SpecM
                • Oct 2005
                • 4531
                the knock senser code could be holding the timing back
                1989 cirrisblau-metallic 325i
                • OrganicMechanic
                  • Jan 2008
                  • 1719
                  check this thread...
                  click here
                  join the E30 Cabrio owners gruppe
                  click here for details
