e24 differential
  • mrhinton
    • Nov 2008
    • 157
    e24 differential
    would either a 633csi or a 635csi have an lsd?
    if so would it be a medium case or large case and what would the ratio be? 3.46?
    how much would it be worth?
    a junkyard near me has both cars and i wanna use the diffs.
    thankx!
  • Massive Lee
    • Sep 2006
    • 6785
    Side loaders. Yes, they were available with LSD.
    Lee
    massivebrakes.com
    • mrhinton
      • Nov 2008
      • 157
      so its not guaranteed to be a lsd. i was under the impression that because it was an cSi it would be limited slip. i see what side loader means but im still unsure as to whether it can be swapped into an e30 without major work.
      • FredK
        • 14762
        It is a medium case diff. I spotted a 635CSi at the junkyard, but somebody already pulled the diff out. It will bolt up as long as you swap the rear cover to the E30 medium case rear cover, and the output shafts. These pop out and pop right back in.
        • napabavarian
          • Jun 2008
          • 834
          If the rear end is jacked up then spin one rear wheel, if the opposite wheel spins the same way (both foreward or both reverse) it is an LSD, if opposite it is open, parking brake must be off, transmission in neutral.
          This place is like catholic school, 2/3 of the students smoke weed on a daily basis, but the faculty seems to convince the outside world that drugs are just in the other schools, the resident pot dealer thinks he's cool because he has the originality to call anyone he doesn't like a homosexual, and most of the little children follow him like sheep, then there's the few with brains, you hardly ever hear from them, perhaps don't even know they exist, but they get all the sh!t done.
          • rThor432
            • Feb 2007
            • 3907
            If I remember right, all manual 6ers were equipped with limited slip units. All of the ones I've ever worked on have been, as well as the ones I've owned. Just a tip.
            • ZM Blue Devil
              • Dec 2006
              • 13836
              Hope this is not too much a thread jack but...
              So will a side loader work in a e30? I have a brand new one from Metric, was planning on selling and getting another one as I thought it didnt work on a e30.
              Thanks
              ZM
              Levent
              %20levent@gutenparts.com
              Ladies:
              • FredK
                • 14762
                Ah. Early E24s used the E12 sideloader rear end, up until 9/82. Later 633s from 9/82 used a medium case diff that we are all familiar with. All 635s used a normal diff.
                • BenM
                  • 2184
                  88-89 635csi Manuals came with the 3.64 ratio in a Medium case. A very rare diff indeed.
                  Originally posted by BillBrasky
                  E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                  1991 318i Alpine II - S50/5-lug swapped - track car
                  1989 325i Cirrusblau - Daily
                  1970 2500 - Malaga over Grey Cloth
                  2012 F350 6.7PSD
                  • vic_325
                    • 264
                    i may be getting a manual 85 635csi parts car to use for my m30 swap.
                    just want to know, did all 635csi's come with the 3.64? or 3.46? what ratio is known to be in the 85 635csi's
                    Vic.
                    • LowR3V'in
                      • 4209
                      which cars and models came with the big case?
                      I always though all the big six/ v12s came came with big cases.
                      • BenM
                        • 2184
                        Vic.
                        Most likely a 3.25, though it may be a 3.46
                        I believe medium case 3.46's are mostly found on '88 528e's and late (85-87) E23 735i's.
                        2012 F350 6.7PSD
                        • M-technik-3
                          • 18946
                          Correct, the E23's some of them had LSD's and 3.64's were optional in E30's in EU.
                          • vic_325
                            • 264
                            theres a 88 528e 5 speed at my local junkyard. i took a look at it and the metal tag had 3.25 stamped on it...(non S)
