How to turn off checkpanel
  • Glaede
    • Oct 2007
    • 138
    Hey there,
    How do you guys turn off the oil level sensor in the check panel? The oilpan E34 sensor is missing and i don't intend to buy one right now.. This is of cause an M50 engine i'm talking about in my '87 325i.
    I've heard something about a resistor and to wires two ground, but i can't find that topic again (on a danish forum)..
    All you guys out there must have done this a million times :)
    /Soeren from Denmark..
  • hugh jass
    • 2220
    why not just remove the bulb from the check panel?
    my son's name is Soren....
    here is what you posted last year "After searching and reading a lot, it seems that pin nr. 2 needs ground and pin nr. 10 needs ground through a 1000 ohm resistor. Probably gonna try that out tomorrow."
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • Glaede
      • Oct 2007
      • 138
      Doh i totally forgot.. Thats actually what i need! Thanks
      • 1990m3
        • 1180
        I just unplugged mine -- couldn't be happier
        • rThor432
          • Feb 2007
          • 3907
          Mine lights up like a Christmas tree every time I get in. I just tell the passenger I hope it'll get us where we are going with no oil, coolant, lights, and no washer fluid.
          I'd just take out the bulbs if I were you, or unplug it.
          • uberCerealkiller
            • 221
            i'd either fix the problem or just take the bulb out like everyone else has said. In a perfect world you could fix it and it work properly, but check control crap never works properly......
            Originally posted by Beastolizer
            what is the difference between the 12 LED and 6 LED and 24 LED?
            Originally posted by norcalE30
            you may want to sit down, this is complex...
            one has 6 LEDs, one has 12 LEDs, and one has 24 LEDs
            • Spinning Tires
              • Feb 2007
              • 283
              i thought they were led's on a circuit board. but who knows its been a while since i had one apart
              First: 1984 318i
              Second: 1987 325
              Third: 1987 325is
              Current: 1990 325i (Soon To Be 335i)
              • Fidhle007
                I can fly, motherfucker
                • Oct 2005
                • 7209
                Mine works.
                '89 325is S50 Track Montser
                '04 X5 Daily/Tow Vehicle
                http://www.avarestoration.com
                http://www.myspace.com/brendanfiddle
                Click here if you want to be my zombie slave...
                http://www.youtube.com/user/Fidhle007
                • Glaede
                  • Oct 2007
                  • 138
                  But if you just unplug the bulb, then the Check will still flash in the speedometer, right?
                  • TreFlip
                    • Jan 2009
                    • 107
                    you cant take out the bulb for the engine oil light. you can take the light out the whole check panel. how do you go about just fixing it? anyone know?
                    1990 Schwarz 325i - Parted out
                    1990 Schwarz 325i - Totalled
                    1990 Calypsorot 325i - Sold
                    1989 Schawarz 325i- Current
                    • 1990m3
                      • 1180
                      just take off the plug that goes to the back of the check panel. Then it's just decorations
