soon to go s 50 / getrag 260..."rebld" drivshaft?
  • JRKOUPE
    • Dec 2004
    • 3159
    Hey all......about to embark on an s50 swap using my 125k mile getrag 260 and driveshaft.......
    Ill do a new center bearing of course.....
    my mechanic feels that an oe 125k driveshaft w/ orig u jts should be freshened up, esp considering itll now have to deal w/ 240 hp....I am just not sure this is needed....but I can be swayed....any1 here do this....new u jts and "zerx" fittings?...
    It would cost several hundred dolla bills yall.......skip it?....or do it?....I dont recall any1 ever doing it here.
  • BenM
    • 2184
    Joel,
    In addition to the CSB, definitely do the guibo as well. I think its less than $50.
    As far as a driveshaft rebuild, I'd say skip it for now. Though an S50 will put an increased amount of stress on your driveline, if you weren't having problems before, than you shouldn't have any now. Just my $.02, but others may say go for it.
    If you drive smooth (i.e. not shift hard and fast), that would also contribute to less wear in the driveline.
    HTH and look forward to chatting with you at LRP this year.
    Ben
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • SpecM
      • Oct 2005
      • 4531
      you will have to pay a machine shop to cut the joints out, machine the yokes, and press in new "greaseable" joints, and balance the unit
      or buy a new shaft
      1989 cirrisblau-metallic 325i
      • hugh jass
        • 2220
        i say skip it, just drive it until the driveshaft gives out, which may be a long time. spend the $$ on something more fun.
        ______________________
        ex-Chief Operating Officer
        Blunt Tech Industries
        West Coast and Pacific Rim
        • JRKOUPE
          • Dec 2004
          • 3159
          or buy a new shaft
          I hear ya....I was quoted close to 400 for all the work.........Im not sure its money well spent.....Ive just never heard of issues from any "swappers"........and my shifting prowess is like butta(hehehe)......I wanted to hear your thoughts...
          • JRKOUPE
            • Dec 2004
            • 3159
            Originally posted by BenM
            Joel,
            Ben
            Hey B
            hope all is good......any dates set yet for some track time?.....
            Im doing mid april to start at lrp.....
            • BenM
              • 2184
              Originally posted by JRKOUPE
              Hey B
              Things are good, hope all is well with you too.
              I'm set for April 10th with the CVC, then I may try another track. Maybe Watkins Glen or Thunderbolt.
              You doing yours w/ NASA?
              2012 F350 6.7PSD
              • Uber E30
                • 1409
                OP, can you type in ENGLISH next time. I now have a headache after reading your post.
                I say skip the rebuild. Its not like a driveshaft is that hard to replace if it goes bad.
                -Alex
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  april is w/ PCA
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    Uber...Im leaning toward agreeing w/ your thoughts.
                    Re my typing.....its a car forum...not a medical journal....
                    what did you have problems with?...seems simple to me...and most others.
                    • rThor432
                      • Feb 2007
                      • 3907
                      Plus one. If it isnt broken, dont mess with it. I would never rebuild a driveshaft if there was no play in the U-joints. No point in my opinion.
                      For what it's worth, my driveshaft is all original (U-joints anyway) with 250k-ish on it. My S52 hasnt managed to blow it up yet.
                      • mattdk318i
                        • Jun 2006
                        • 3953
                        what are you using by way of shifter?
                        • JRKOUPE
                          • Dec 2004
                          • 3159
                          Matt.......wazzup.
                          I m using my orig 260 that has a z3 set up.....w/a threaded shifter to mate w/ my custom threaded delrin knob......I was keeping your "de rotation " modded parts in the back of my mind....are you still doing them?......I had thought that thread died out a bit....but I havent checked in weeks....
                          It seems kind of clear to me Ill leave the ds alone....till it breaks. I appreciate all the input..you guys rock.
                          • gazellebeigem3
                            • Jun 2005
                            • 3712
                            yup. The drive shaft im using on my swap has over 200k, but the csb was recently replaced and the u joint operated smoothly, and even now with 10k or so its still fine.
