Which would be the better option?
  • Mohammed_A
    • 344
    After playing around with different engine mounting arms and mounts i finally got the motor to sit snug but have a choice of how i would like it to sit....
    option 1: motor would sit straight with the gearbox going high into the tunnel, almost touching the padding or maybe even touching.
    option 2: motor would be slightly tilted towards the firewall and the tappet cover would touch the firewall but the gearbox would sit in almost the original position...
    i am using the s50 with 260 getrag tranny, which would be the better option to choose, with option 1 i would obviously use spacers or modify the gearbox cross member to be higher on one side,
    with option 2 i use the stock cross member with very small spacers on the mountings...and the intake plenum is quite tight...
    please help
  • mbonder
    • 2255
    There is actually a guy on here (white325is I think) who makes custom brackets for this specific combination. That would put everything right where you want it to be.
    • Mohammed_A
      • 344
      thanks for the help but i think the distance is a problem, shipping would be expensive as well as my weak currency against the dollar but thanks anyway....
      anyone else have any ideas?
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        Search around here more. I have seen (but can't remember where) on here about a combination of E28 mounts and E30 mounts with the stock cross member that works well.
        Maybe one of the 24V gurus will chime in with a link or an explanation.
        -Andy
        • So Live
          • 2512
          Keep in mind he's from SA so his s50 is the real one, not our 3.0 liter m50...
          Personally i think keeping the tranny in the original position would be better just because of drive shaft angles and whatnot. And technically your CG would be that much lower but i doubt itd be noticeable. Let someone more knowledgeable chime in though.
          Good luck figuring it out!
          -Chris
          • jrdeamicis
            • Nov 2008
            • 956
            Well the guibo does not have a U-joint. Only the first connection before the CSB. You are going to want the guibo tohave even load across all the bolts so you do not prematurely wear it down.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • Mohammed_A
              • 344
              i used the e28 mount and e30 mount on the stock cross member and works fine, then it sits with the gearbox high in the tunnel...both ways work , obviously the selector rod needs to be bent, which i still have to do but other than that touching there is seems to be nothing wrong with both the ways....????
