What oil pump is needed for m50 swap
  • Roach
    • Feb 2021
    • 12
    What fuel pump do I need for m50 swap with front sump oil pan
  • e30strokr
    • 211
    say that again?.. oil pump or fuel pump?
    you should be fine with the fuel pump as long as you have the correct fuel regulator....
    oil pump should be the same... you just need the correct oil sump/pickup tube
    going thru this myself and i didnt change any of those..
    • Roach
      • Feb 2021
      • 12
      yes meant oil pump, thanks for info and the pickup is just the normal short one (pictured) correct? Or do I need the longer pickup
      • e30strokr
        • 211
        yes it should be the shorter one since its not going to the rear of the block, check part#, dont forget to either weld, strap or red loctite the screw for the oil pump
        not an expert but im just about ready to put the M50 stroker into my E30..
