I need a list of what is need it and if possible a diy document. I found a S 54 for 4K any thoughts
S54 swap list....
I'm sorry to do this, but searching is your friend, there are a few members here that have done this swap without a DIY document, and nobody is just gonna hold your hand.
There is a member here that will take your core subframe and oil pan and modify it, there is another user that makes transmission crossmembers, there is yet another that will help you with the software for the DME, and there are a multitude of other options that will depend on the model and engine you currently have installed in your e30.
Formulating a cohesive, succinct post requesting help would be likely responded to in a more desired method that would better help you reach your goals.
Also, further info regarding the s54 you found would likely assist people giving you advice. The year, and mileage would be a good start. -
Yes agree I'm in the middle of my S54 swap and you will need to do a lot of reading and decide what options you want to have. Go to TylerT on here for his awesome front subframe and oil pan also he makes the 6 speed trans brace. By this summer he will be the first to make a full swap headers and full exhaust, I'm the first to get it and he's about half done with it so far....Comment
