Quick dumb question
  • 89AlpineM3
    • 548
    Quick dumb question
    Where would I run the brake booster vacuum line if I have deleted the stock S54 intake housing?
  • Liquidity
    • May 2014
    • 395
    Any large port that's between the throttle body and engine is fine. Must be between the throttle and engine or else it won't see any vacuum when you lift off the gas and will defeat the purpose of the booster.
    • DesertBMW
      • Aug 2011
      • 1038
      Intake housing has nothing to do with vacuum source. You would run the booster hose to the same location as it is in 2003 M3.
      LOL, that answer is funnier than the question.
      • Liquidity
        • May 2014
        • 395
        Why's that? An engine is an engine. On any engine the greatest vacuum is developed between the throttle body and the intake valves when the throttle is closed. This is where the booster gets its vacuum from on every engine with a throttle plate.
        And where would that be? Something tells me he doesn't have a 2003 M3 sitting right next to him or else he wouldn't need to ask the question.
        • 89AlpineM3
          • 548
          Ya that was my question is I don't have another M3 to look at currently
          • DesertBMW
            • Aug 2011
            • 1038
            Originally posted by Liquidity
            Why's that? An engine is an engine. On any engine the greatest vacuum is developed between the throttle body and the intake valves when the throttle is closed. .
            There you go
            You had the M3 there when you were removing that S54, so you did not take any photos? Didn't remember were it goes
            • 89AlpineM3
              • 548
              Got my answer , runs off the vacuum line next to the fuel rail... Not where a stock E46 had it as that wouldn't have helped
              • DesertBMW
                • Aug 2011
                • 1038
                E46 has to get it from there because that is the only vacuum source on the whole engine.
