Hi,
I was finding the web-based WDS and the SVG images a major pain in the arse to work with.
So I exported a bunch of key ones to Illustrator and spent too much time fixing them up because the import didnt work well.
Anyway, I created them as a scalable PDF, so you can zoom right and it will not pixelate. I havent done everything, just what I need to figure out the wiring to integrate with a Motec M800.
For the good of you all, here are the PDF's
- Starter control - https://dl.dropboxusercontent.com/u/...%20control.pdf
- VANOS valves - https://dl.dropboxusercontent.com/u/...s%20valves.pdf
- Ignition coils - https://dl.dropboxusercontent.com/u/...on%20coils.pdf
- Fuel injectors - https://dl.dropboxusercontent.com/u/...0injectors.pdf
- Idle control - https://dl.dropboxusercontent.com/u/...20Actuator.pdf
- Coolant temp - https://dl.dropboxusercontent.com/u/...p%20sensor.pdf
- Drive by wire - https://dl.dropboxusercontent.com/u/...entiometer.pdf
- Cam sensors - https://dl.dropboxusercontent.com/u/...m%20sensor.pdf
- Crank sensors - https://dl.dropboxusercontent.com/u/...k%20sensor.pdf
Now, obviously not claiming any copyright etc, that is all the original author. All I've done is transcribe to make them easier to work with.
You're welcome :)
You're welcome :)
