M54B25 in a Z3 - Very Rough Idle, INPA Screenshots
  • KI4UJO
    • Jun 2011
    • 642
    Ok, I know this isn't exactly a Z3 forum, but r3v is normally pretty useful, so help me out here. My dad drives a 2001 Z3 2.5. As of a few weeks ago, he began to notice a loss in fuel economy and a rough idle. Now, the car will barely idle(attempts to stall) , but does seem to run ok once you are above idle.
    Upon discovering these issues, I went ahead and replaced the CCV with the upgraded cold-weather version. There was oil present inside the intake, but it did not solve the issue. Also, I replaced the plugs with a set of NGK BKR6EQUP.
    My current thought: VANOS seals (car has 250K, it realistically couldn't jurt to replace them anyway)
    Any ideas? He needs this to drive to work, so I realistically need to get it figured out quickly.
    1 by Jonathan Martin, on Flickr
    2 by Jonathan Martin, on Flickr
    3 by Jonathan Martin, on Flickr
    IMG_0145 by Jonathan Martin, on Flickr
  • sublimation
    • Jul 2013
    • 155
    Maf?
    • 328ijunkie
      • May 2007
      • 3961
      MAF/Vac leaks still
      Check Us out on Facebook
      Full Product Line Tuning
      • KI4UJO
        • Jun 2011
        • 642
        I found a valve cover gasket leak, so I've got one on order.
        • KI4UJO
          • Jun 2011
          • 642
          Replaced the gasket, but the issue still unfortunately persists.
          • KI4UJO
            • Jun 2011
            • 642
            Solved: it had a defective DISA valve (O-Ring was bad,along with the vacuum actuator no longer functioning)
