s54 no crank issue
  • two240s
    • Apr 2009
    • 395
    Originally posted by FredK
    Weird. I haven't seen a BK/WT/YL wire in an E30 before. Is this an early E30 M3? So that connector goes from C200 pin 10, and terminates with that connector? Does it look like there's a corresponding connector anywhere else?
    7/87 build date
    Yep...exactly. No other plugs like it in that area. Just the black/yellow wire (that goes to s233) that was cut and taped right above it.
    • FredK
      • 14761
      I was just thinking about this... could that been part of a BMW dealer installed alarm / immobilizer?
      • two240s
        • Apr 2009
        • 395
        I definitely didn't remove anything like that when I pulled the s14. It has been a couple years since I pulled it, so I'm thinking maybe there was some other wire running to the starter separately that I don't remember. I don't know
        • Dave V
          • 20
          Originally posted by Andrew325is
          Has EWS been disabled in the ECU? And you have all 5 connectors on it? ?
          Should I take this as if EWS is deleted I still need the EWS box and key/ignition ring?
          • two240s
            • Apr 2009
            • 395
            No, ews is deleted in the DME. You won't need anything extra
