Operation Phoenix is in Full Effect
  • BMW_TUNER
    • Jul 2006
    • 1377
    Got my 2-1
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • BMW_TUNER
      • Jul 2006
      • 1377
      Got the motor mounts on the E46 mount cut down the engine degreased the Z3M harness on
      Waiting on new Exhaust studs for my headers
      Still, a bit confused by the wiring but I am sure that some of the confusion will be reduced when Andrew send me the harness. I just sent him the DME today
      • BMW_TUNER
        • Jul 2006
        • 1377
        Got the intake TB's to this but they aren't perfect so I am going to wait for a few things for my Dremel to come in and work on it using that.
        • BMW_TUNER
          • Jul 2006
          • 1377
          I have purchased an S54 fuel pressure setup is there any interest in having an adapter made to make it hookup to a Standard fuel line? I will be figuring this out soon anyway. I know there is a from someone else but it is expensive.
          • BMW_TUNER
            • Jul 2006
            • 1377
            Subframe and Oil pan are here and they look great, worth the long wait for sure. I will stab the motor as soon as Tyler sends me the smaller baffle cover for this style pan and then it will be wiring fun. Should be too bad with Andrews great harness and assistance.
            Love the new sway relocation options from Tyler.
            • BMW_TUNER
              • Jul 2006
              • 1377
              Its in and its running ( after fuel pump priming issues that were resolved by relay swap and cleaning).
              It idles like crap after idling ok for 20-30 seconds. Scanned the car and got these codes.
              139
              8B
              P0564
              Interruption, cruise-control operation
              81
              51
              P1568
              Interface, multifunction steering wheel
              132
              84
              P1613
              CAN timeout DSC
              133
              85
              P0600
              CAN timeout, steering angle sensor
              134
              86
              P1612
              CAN timeout, instrument cluster
              14
              0E
              P1602
              DM-TL Heater
              137
              89
              waffles
              Suction-jet pump
              66
              42
              waffles
              EWS interface: no communication
              144
              90
              YES
              Function, oxygen sensor control, cyl. 1-3
              43
              2B
              waffles
              Signal, temperature sensor, radiator outlet
              106
              6A
              waffles
              Signal, brake light switch
              and 145 shortly after that. The oxy sensors appear to be cooked and that is why it likely cant idle well. Over time it drops into loop its getting shitty signal. I need to finish the exhaust. I am going to run the dual 60mm off the oem section two my brother gave me and merge them into a single 3 inch that I built for the FI setup. On the headers I could not get the oxygen sensors to fit in either location of the 4-6 header so I had to add it just after the collector. One capped bung for the 1-3 header is super close to my subframe and may require further attention. Its crazy to scan an E30 with INPA!
              • Wolfman
                • 341
                [ATTACH]117518[/ATTACH]
                • BMW_TUNER
                  • Jul 2006
                  • 1377
                  So the S54 is in and running the only consistent issue I’m still having is a little bit of seepage from the thermostat housing Overing but otherwise it’s fantastic. Break in mileage is on the motor and revving to 8000 RPM is amazing. Need to swap in 3.25 LSD as ZF 320 and 3.73 is extremely short for a higher RPM motor, first gear is completely unnecessary, car has great mid range and absolutely screams up top but I have to grab gears very quickly. Have learned many lessons from the swap and in looking at trying to produce some parts to make the whole thing a little more simple less fabrication for DIY .
                  • diesekte
                    • Sep 2013
                    • 417
                    What you need to do is use the 420g like yours truly :D
                    Honestly though 1st gear is still useless. I have a 3.73 as well.
