So I had my E30 S54 swap aligned today and on the way home my gauge cluster battery/Brake Fluid and Parking Brake lights would come on and then go out. Now they are just on al the time. The car is still running fine but something has happened to the feeds from those sensors or the grounding. Anyone else have similar issues? I am 99% sure its not my 1 year old Bav Resto Cluster. Any input or help is appreciated. I am using the harness from Andrew and it was all working fine and it is still all working but lights are now on and wont go out.
Cluster issues Help needed lights on ?
Also should note that the car has a new Z3M wiring harness that worked perfectly with Andrews set up until yesterday. Pulled some preliminary codes off the DME definitely shows low voltage also some oxygen sensors stuff and TPS issues because I forgot to reattach TPS after doing an oil change but nothing else at this point at this point I’m leaning towards dead battery or alternator.1989 332IS -S-Fiddy Four-Some weight removed.
5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
