Im working up to swapping my 318is with a m54. I understand that a G240 will fit a M50 the same as it bolts to my M42, and bolt properly in the car (not shifted 10 degrees). I would also need a 325i shiftier and a E36 drive shaft.
Now my question is if i ran a G240 would I need to use the M50 E36 engine arms? or would the standard m54 530i arms work?
Any reason I shouldn't do this?
