So, I am doing M54B30 swap.
I have wired the wiring harness as per Jordan's guide, and for some reason the DME is not activating the Fuel pump rellay.
I have done the following test:
If I disconnect the relay from the DME (pin 10 on x6003) - I get proper ground (roughly 2 sec when on acc position and when I start cranking)
If I give ground directly to the pin on the relay - relay activates fine car starts and runs, however I get an error "Fuel pump relay ground or open"
I am using proper K96 relay, tested with several other relays that are tested and work fine - no luck.
Tried to disable the Fuel Pump Relay error code - no difference.
Any help/advice would be greatly appreciated.
