Humm in the rear? At certain speeds
  • Phoney36
    • Oct 2013
    • 30
    Did this issue ever get resolved. Mine is doing the same thing from the same rear left section (driver's side) and I'd like to get it fixed.
    Thanks in advance.
    • ghatid
      • Sep 2013
      • 151
      My 325ix had a humming also in the rear left. It was the wheel bearing for me. BTW, it is a pain in the buttocks if you do this yourself and you don't have the $400 BMW tool...at least for me. I used a normal wheel bearing press + some other pieces and it took me forever to take out/put in.
      • EyExR
        • Jan 2011
        • 959
        Could be the other wheel bearing... Also - make sure your ebrake isn't rubbing.
        After that, I would be questioning something in the VC. Does it happen in neutral?
        My 325iX DIY Threads:
        Front Wheel Bearing Replacement
        325iX Rear Subframe Bushings and MUCH more w/pics!
        325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
