Howling from front right
  • s_hemphill
    • 64
    Hey guys, something has started to howl from the front right. It starts after the car has been driving for a few blocks, and goes away when I put on the brakes or steer one way or the other. It isn't the wheel bearing because I replaced that thinking it was the problem. Any ideas?
  • redhatpat
    • Aug 2005
    • 656
    Maybe the brake pad vibrating in the caliper?
    • dogsbark26
      • Nov 2008
      • 533
      What you describe sure sounds like wheel bearing.
      • s_hemphill
        • 64
        yeah. I thought it was the wheel bearing for sure. In fact, I replaced it twice thinking maybe the guy somehow put it in wrong. To make things more confusing, the noise went away for about a week after each bearing replacement. I was thinking that since I didn't lube the splines, maybe the axle is somehow sliding in out and making noise due to an imbalanced wheel, but I think that's a long shot. Another guy said that it could be the pads, too, so I'll check it out this weekend. Maybe there's a rock or something like that stuck in there...
        • z122643
          • Aug 2011
          • 286
          Does the sound increase on turns? I'm thinking you have a warped rotor which is removed after each wheel bearing replacement which would solve your noise issue for a while.
          [/SIGPIC]"we are so totally screwed!"
          • bmwguy325is
            • May 2011
            • 1263
            I think you have a caliper that drags or sticks.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • s_hemphill
              • 64
              I ended up bleeding the brakes and it went away. Thanks, guys.
