325i and 325ix rear wheel hub differences?
  • jute91
    • Nov 2011
    • 581
    is there some differences between 325i and 325ix rear wheel hubs? because im wondering if i could put real wheel drive hubs and brake disc on my ix, i could use low ET wheels. noticed that ix brake disc has more ''ET'' coming out.
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
  • MikeDE
    • 1873
    According to realoem.com, the parts #'s are different. BUT the 325i rear hubs are common enough, get one and compare it to the iX hub.
    -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
    • 325ix
      • Aug 2009
      • 7783
      This seems like a decent idea, I highly doubt it will work though.
      • spdracrm3
        • Sep 2009
        • 959
        yes IX hubs are deeper to make up for offset in rim and for track width to match the front due to FWD components on IX front struts. if you try to put rear IX rotors on rear 325i hubs they will hit the backing plate ,i know this for a fact as ive been swapping rear trailing arm components from a 325i onto my IX trying to find track down toe issue ,which is looking like a bent subframe
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • jute91
          • Nov 2011
          • 581
          But when using 325i brake disc with its hub, it wont hit backing plate? cos those brakes disc are different too?
          • spdracrm3
            • Sep 2009
            • 959
            right ,the backing plate and parking brake assemblies are the same and in the same location on both ,just the hub is deeper and consequently drum portion of rotor is deeper on IX. so if you swap to 325i hubs the the 325i rotors will fit perfectly with normal clearances
            Angus
            88 E30M3 X2
            89 325IX
            92 R100GS/PD
            • jute91
              • Nov 2011
              • 581
              so, here i come ebay. gonna start looking for BBS RS
              • spdracrm3
                • Sep 2009
                • 959
                so what do you plan to do on the front where you cant change hubs and therefore offset?
                you going to run different ET wheel front and back?
                Angus
                88 E30M3 X2
                89 325IX
                92 R100GS/PD
                • jute91
                  • Nov 2011
                  • 581
                  im going to count difference within hubs, then pick up wheels that comes out directly same distance. rear 8-9'' wide front 7-8''
                  • MikeDE
                    • 1873
                    That's good to know...
                    • LuckyHenriksen
                      • Jun 2010
                      • 4244
                      If you need a new subframe I have some
                      Bahama Beige E23 Project
                      Bluebird Bus Conversion
                      New Oregon Trail
