transpher case removal
    Do you have to remove the transmission at all to get the t case off
    you do not. manuals are harder to remove than autos because the top two bolts are hard to get to. with a u-joint socket a short extension, another u-joint, and another 2 feet of extensions, you can get to them after you remove exhaust, heat shield, drive shaft, trans brace and let the rear of the trans down a couple inches.
    Gigitty Gigitty!!!!
      Correctomundo
      More info here: http://www.e30tech.com/forum/showthr...=100026&page=3
      current fleet: '89 325is; '91 325ic; '88 325is; '91 325i
