iX Manual Transmission question
  • jcollins@northwestern.edu
    • Mar 2007
    • 26
    Does iX have an unique tranny or is it the same Getrag 260 used with the other M20 models? Thanks!
  • gearheadsteve11
    • Aug 2009
    • 65
    It's unique to the IX. From what I understand the guts are mostly the same, but the output shaft and flang is designed to bolt to the transfercase.
    • spdracrm3
      • Sep 2009
      • 959
      exact same Getrag 260 trans 2wd or AWD ,just the tailshaft housing is different to mount the Tcase to (and this changes some of the shift mechanism parts also). you can take a standard 2wd trans and swap the AWD tailshaft housing to it and put it right into an ix. even the gear ratios are all the same .... but the diff ratios change to make up for added weight
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
        • Mar 2007
        • 26
        Thanks for the gr8 info!
