Clutch Slave replacement
  • Bolestuff
    • May 2012
    • 51
    I was wondering if it is possible to get the slave cylinder out of the ix without removing the front drive line? It just looks really tight. If it does need to get pulled, are they any things I should watch out for? Other then to make sure it goes back in the same alignment it came out of course.
    Thanks
  • Stabmasterflex
    • 59
    Ill have a look at mine hopefully tonight. Perhaps just lowering the tranny will give you room? If your replacing it, bleeding it is usually the worse part. That can be a pain.
    • gearheadsteve11
      • Aug 2009
      • 65
      No need to pull the front drive line. I just did mine yesterday, used a 3" extension attached to a 12mm socket, behind that a wobbly/u-joint, and then a longer extension to my ratchet. (Note: I used an air ratchet, but the ratchet is out in the open with the wobbly attached so same deal.) And as far as getting the slave cylinder out, just work it around, and you can pull it down out of there after the nuts are off.
      • Bolestuff
        • May 2012
        • 51
        Thanks man, just what I was looking for. Time to get her back on the road, winter is coming!
        • EyExR
          • Jan 2011
          • 959
          yup. just use extensions and a u-joint. Just did mine as well...
          My 325iX DIY Threads:
          Front Wheel Bearing Replacement
          325iX Rear Subframe Bushings and MUCH more w/pics!
          325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
          • Bolestuff
            • May 2012
            • 51
            Took 1 hour with the correct tools. The self bleeding worked like a charm, just keep the reservoir full as you go.
            Thanks for the tips gang!
