Anyone know how many mm the stock rear spring pads are? I wanted to...
  • audiquattrot
    • May 2008
    • 3836
    possibly go with a bit thicker rear pads just to raise the rear a bit, since the car has a reverse rake on w/ the H&Rs.
    Curious if anyone has done the same, or knows or another BMW spring pad off any other model car I can use that might be a bit thicker.
    Thanks
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • jute91
    • Nov 2011
    • 581
    install heavy duty springs from wagon?
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
    • audiquattrot
      • May 2008
      • 3836
      its just a marginal diff in mm that i want to raise the back. I'm gonna try just stacking another set of spring pads in the rear
      #snwmble
      Current:
      Past:
      • litu
        • 844
        Doo some wood plates is there, I have 7.5mm+5mm rubber bellows+1 cm some hard of wood in there. Now is little front down....
        https://www.facebook.com/Cry_77_IX-110483784967661
        https://www.instagram.com/cry_77_ix/
        • flyboyx
          • 8371
          huh, i never thought of wood. i guess it would work. as far as the spring pads are concerned, i think they are about 4 or 5mm or so. the lower one is shaped like madona's bra. you could get a few from a junk yard parts car, just cut out the center and stack them on.
          Gigitty Gigitty!!!!
          • audiquattrot
            • May 2008
            • 3836
            Yup I got a couple lower ones and plan on cutting the hole a little larger and stacking like you said. Still debating if I should put the cut up one below or above the existing one.
            #snwmble
            Current:
            Past:
            • litu
              • 844
              Yeah they work. I was putting new rubbers in there. And then they found wooden. My older ix has had made ​​such like "spacer" in thera
              • guardodoc
                • 154
                spring pads
                rear upper spring pad 33531094754 is 14.5 mm
                rear lower spring pad 33531136387 is 10 mm
                raises height 10mm total from stock spring pads on 325e
                not sure what stock is on ix
