Humming coming from the rear at all speeds. Fluids question too...
  • audiquattrot
    • May 2008
    • 3836
    Have had a slight hum barely noticeable hum for months. Recently it has gotten a bit louder, but not wheel bearing loud like I've experienced in past cars. The noise doesn't change pitch turning the wheel at speeds, which was normally the case when my old Audi had bad rear wheel bearings.
    Could it be he differential? I always thought that a bad rear diff would only make noise when you accelerate. This makes noise even off the throttle.
    I'm going to change the fluid this week front/rear.
    75w90 for the diffs the choice you guys use? I could've sworn I used ATF on the front diff last time I changed it....but honestly I can't remember for sure
    Also while I'm in there, I'll be changing the tranny (manual) fluid....MTL 70w80 ok?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • e30jps
    • Sep 2011
    • 285
    Front differential:
    Spec: 90W GL-5
    capacity: 0.75 qt
    drain/fill plugs: internal (Allen) head, Size ?
    commonly used after market oil: Redline Synthetic 75W90
    Rear differential:
    Spec: 90W GL-5
    capacity: 1.8 qt
    Manual Transmission:
    Spec: 80W GL-4
    capacity: 1.4 qt
    drain/fill plugs: internal (Allen) head, Size 17MM
    commonly used after market oil: Redline Synthetic MTL (manual transmission lubricant)
    Transfer case:
    Spec: ATF
    capacity: 0.6 qt
    commonly used after market oil: Redline Synthetic ATF
    • audiquattrot
      • May 2008
      • 3836
      Thanks for the list.....other sources I've read said to use ATF on the diffs which made no sense to me.....I think worldpac recommended that. Weird
      #snwmble
      Current:
      Past:
      • e30jps
        • Sep 2011
        • 285
        No problem man!
        Maybe try and use this to find the noise its help me.... Auto Mechanic's Engine Sonarscope Hearing Device Tool Pinpoint Engine Noise Flex
        Just put the car on jack stands and run the car and maybe can hear the noise with this tool.
        • Sean
          • 5793
          I think I might have the same thing, except it sounds like ti comes from all sides of the car.
          - Sean Hayes
          • audiquattrot
            • May 2008
            • 3836
            its my rear drivers wheel bearing. Getting it taken care of today.
            btw what a HUGE difference replacing the diff fluids. I was getting a pretty nasty vibration up front for over a yr. Couldn't diagnose it for a while, and gave up. Changing the fluid made all the difference.
            #snwmble
            Current:
            Past:
            • Sean
              • 5793
              Hmm, really? Good to know. I think the PO did the diff's fluids, but better check.
              - Sean Hayes
              • Sean
                • 5793
                How many miles are you at?
                I will say...it does sound like something a wheel bearing would do...
                - Sean Hayes
                • audiquattrot
                  • May 2008
                  • 3836
                  I'm at 130k....had the wheel bearing changed and problem solved!
                  #snwmble
                  Current:
                  Past:
