IX Specific Starter?
  • FastAndLight
    • May 2012
    • 62
    My starter fell apart over the weekend and I ordered a new one from my usual place. This morning they e-mailed me to say that based on my VIN the right starter was $400 + core.
    So, clearly I'm not going to go that route. Is there anything iX specific about the starter? It looked pretty normal to me.
    Thanks.
  • EyExR
    • Jan 2011
    • 958
    No....
    And that's a BS price. You can get it for WAY cheaper....
    http://www.turnermotorsport.com/BMW-...-starters.aspx
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    • FastAndLight
      • May 2012
      • 62
      Originally posted by EyExR
      No....
      Thanks for confirming. Yeah, I saw the Turner one, but I went with FCP Euro because I also needed a couple of other things I already had in my cart there.
      https://www.fcpeuro.com/products/bmw...8-bosch-sr443x
      Rock Auto had some even cheaper...but I wanted the Bosch reman'd one. I've also had a bunch of bad experiences with Rock Auto, but FCP has been solid every time.
      • mtnbimmer
        • May 2012
        • 73
        Good price on the FCP unit. FYI, you can get a OE (factory) refurb unit for almost the same price from here:
        I get all my factory parts from these guys and the prices are great. The benefit of buying OE is that all factory parts carry a two (2) year warranty.
        Good luck changing that out. I have never found an easy way to get to that back bolt.
        • FastAndLight
          • May 2012
          • 62
          The dealer near me has a similar setup to husker...except I can go and pick it up locally which is nice. They are the ones that e-mailed me back about the change in price from $130ish to $400. Not sure what happened, but I asked them twice, and they said that was the price.
          I've already got the old one out.
          I used a wobble head and a 6" extension on the back bolt. From the bottom I was able to feel it and get the wrench in there. For once the rust on my car was a help, as I think it was holding the bolt in place while I wrenched the nut off.
          For re-assembly I have pre-positioned a u-joint and some extensions on the head of the back bolt. I'll let you know how it goes.
          • FastAndLight
            • May 2012
            • 62
            As an aside on the warranty issue, the Bosch reman starter I got from FCP has a 2 year warranty. I'm going to put it in this morning, but I think it will be pretty straightforward.
            Sent from my One M8 using Tapatalk
