Turbo prep questions
  • Bimmer_man
    • Jan 2013
    • 1478
    So I will be turbocharging my iX and i want to know what are some areas that need reinforcing i know the front driveshaft but thats about it. If you have any input in what can break on the iX let me know.
    my set up will be 7 -10 psi dd and 15-18 track.
    Float like a cadillac sting like a Bimmer!:)
  • Nisse Järnet
    • Aug 2013
    • 1221
    Front diff, depending on your driving.
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      I thought you were doing an s54?
      • Bimmer_man
        • Jan 2013
        • 1478
        I picked up an ix so no s54 for that. And what about the Diff?
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          • Bimmer_man
            • Jan 2013
            • 1478
            That's bad ass but way too much work. I'm happy with a m20 turbo in the ix.
            • AudioNToxication
              • Nov 2013
              • 117
              I highly recommend you do all the maintenance stuff on the car first before you turbo it, such as check the guibos and ball joints and things like that.
              Adding power will only expose weak areas, you should be ok as long as you don't launch or abuse the car via hard shifts. its a fairly robust drive-train but like anything its not a fan of shock load.
              • Bimmer_man
                • Jan 2013
                • 1478
                Well i got the car practically all taken apart so the normal maintenance stuff will be done. I even got the Gates racing belt. So that stuff will be all taken care of.
