Clutch help!
  • CalebAndSid
    • Feb 2017
    • 10
    Clutch help!
    Was wondering if anyone has any tips / tricks on doing the clutch in a 325ix. Mine went not too long ago and the replacement just arrived today. I was wondering if I need to remove the front driveshaft or drop the whole front subframe of the car. Any help would be awesome!
    Also I should note I am currently doing a lot of work on the car (headgasket, radiator, steering rack you name it) so it is already in shambles and would it be best to do the clutch first and then everything else or save it for last?
    Thanks again!
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5586
    Search, this info is available on this site.
    • Chrisbike
      • Mar 2015
      • 688
      This ^
      Build Thread
      https://www.r3vlimited.com/board/sho...d.php?t=419655
      Parts Thread
      https://www.r3vlimited.com/board/sho...d.php?t=408302
      • jneumss
        • Mar 2016
        • 42
        Since you are doing the headgasket, radiator, and the steering rack, you should just drop the whole front subframe. At that point, you will already have the exhaust manifolds, radiator, intake manifold, power steering, etc. disconnected. I would suspend the engine/trans with an engine hoist, disconnect the front subframe and lower the whole assembly ~10 inches so that you can easily reach all of the bellhousing bolts. Use a transmission jack to support the transmission/TC and separate them from the engine. Install your new clutch, maybe a new rear main seal, lightened flywheel, etc. With the engine suspended you can then disconnect and lower the subframe to replace your steering rack as well.
