Transfer case bearings from motion industries
  • adanzig
    • Nov 2017
    • 18
    As I gear up to do a TC rebuild, I’d like to source substitute bearings that are NLA from BMW OEM. I see the dimension spec for each bearing on realoem however I’m shown a number of choices from motion’s website. I assume a German brand is desired but what other subtleties in spec am I looking for? I see differences in:
    1) internal clearance: C0, C3, CN (which I think is the same as C0)
    2) closure: I believe these are all open vs sealed vs shielded vs with contact seals (single vs double)
    3) snap ring: w or w/out
    4) manufacturer choice: FAG(schaeffler), SKF/MRC, Timkin/fawner seem to be the premium Marques...
    Any insight would be appreciated.
    1989 325iX
    SF, CA
  • D.Martijn
    • Sep 2016
    • 1022
    I just went through this and went with these bearings.
    I went with normal clearance..
    1x NTN K 15X21X15
    1x SKF 6007
    1x SKF 6005
    2x SKF 16009
    1x SKF CR 32X47X7 HMSA10 V
    1x SKF CR 35X47X7 HMSA10 V
    2x SKF CR 44X60X10 HMSA10 V
    1x SKF 6009-2Z
    1x INA HK3224
    1990 325iX Touring - November 2018 R3V Car Of The Month
    1980 Volkswagen Golf mk1 1.1
    1974 BMW 2002 Touring
    Instagram
    • adanzig
      • Nov 2017
      • 18
      1x NTN K 15X21X15
      1x SKF 6007
      1x SKF 6005
      2x SKF 16009
      1x SKF 6009-2Z
      1x INA HK3224
      Thanks for all this! do you recall which bearings are single/double shield vs open (if any)? I haven’t yet dissembled...
      Also it seems as if 123bearing prices are much cheaper than motion industries, not sure of anyone has an opinion on suppliers...
      1989 325iX
      SF, CA
      • D.Martijn
        • Sep 2016
        • 1022
        No problem. Only one bearing is shielded (metal cover), SKF 6009-z2.
        I ordered all but one on Lagertechniek in the Netherlands as I am from Belgium myself. The INA needle sleeve bearing I got from a seller on Ebay as I couldn't found it anywhere else.
        Instagram
        • Eskie
          • Dec 2014
          • 162
          I just ordered some 16009 bearings from 123bearings (6 of them incase I mess them up during install and because they are so cheap). I'll let you know how it goes. I can tell you I already messed up 2 16009 bearings I ordered from VXB bearing on amazon. I pounded them in using an old bearing on top of the new one. I spun them after installation and they sounded worn out already so I'm pretty sure pounding them in is not the way to go. I'm going to try to press them in using an adapter that only presses on the outer race. Just food for thought when you install your new bearings.
          Please post your progress!
          • Eskie
            • Dec 2014
            • 162
            D.Martijn---
            How did you install your bearings? You mentioned a bearing driver kit, was it used in conjunction with a hammer or a hydraulic press?
            • D.Martijn
              • Sep 2016
              • 1022
              Originally posted by Eskie
              D.Martijn---
              Driver kit and the included hammer, had no real trouble installing them. Try heating up the aluminium casing if you have trouble fitting the bearings.
              Instagram
