Fluid levels -
Front differential:
Spec: 90W GL-5
capacity: 0.75 qt
drain/fill plugs: internal (Allen) head, Size 17MM
Rear differential:
Spec: 90W GL-5
capacity: 1.8 qt
Manual Transmission:
Spec: 80W GL-4
capacity: 1.4 qt
Autonatic Transmission:
Spec: Dexron ATF
capacity: 3.2 qt
Transfer case:
Spec: ATF
capacity: 0.6 qt
Good links
http://www.moonlitemotorwerks.com/driveshaft
http://wp1016621.wp027.webpack.hoste...476/f01476.htm
Front differential:
Spec: 90W GL-5
capacity: 0.75 qt
Rear differential:
Spec: 90W GL-5
capacity: 1.8 qt
Spec: 80W GL-4
capacity: 1.4 qt
Spec: Dexron ATF
capacity: 3.2 qt
Transfer case:
Spec: ATF
capacity: 0.6 qt
Good links
