What does cut ABS wires do to the brakes?
  • Chells_88ix
    • 61
    Hey guys, been working on the ix trying to get it going again and while up on the lift I was taking note of the fact the previous owner cut the wires to the ABS sensors on the wheels. I remember him mumbling something about the light staying on, so I guess I am trying to figure out how having those wires cuts affect the normal use of the brakes. Any ideas?
    What would have made the light stay on? If the light stays on is there a way to find out if it is one wheel having the problem or do you have to replace all sensors to find the bad one?
  • Massive Lee
    • Sep 2006
    • 6785
    If any component of the ABS system is not working, then the light goes on and the ABS sytem will be disengaged. The pevious owner of your car is a 100% moron thinking that by cutting the ABS sensor wire it will make the light disapear. Duh...
    massivebrakes.com
    • Chells_88ix
      • 61
      Well I got the same impression. I checked out the wiring where it was cut and it looks like there is enough play to splice it back together. Even though I don't know if it will help find the problem or not. But does cutting those wires have any effect on the braking of the car?
      • Massive Lee
        • Sep 2006
        • 6785
        Originally posted by Chells_88ix
        ...does cutting those wires have any effect on the braking of the car?
        The only effect will be the absence of ABS.
        massivebrakes.com
        • kishg
          • Sep 2006
          • 2624
          x10000
          '12 F30 328i Sport Line
          '91 SpecE30 #523
          '00 Ford F-350 Dually Tow Vehicle
          BMWCCA #360858 NASA #
          128290
          • george graves
            • 19998
            Now, taking out the bulb on the other hand...
            Originally posted by Matt-B
            • supernaughtIX
              • Apr 2007
              • 260
              To find the issue it will eventually lead to getting out a multimeter and your electrical drawings to do some testing. But you can start by wiring that cut one together, cleaning the teeth on the axle that the sensor would see(clogged teeth appear as a lockup to the computer).
              After, check voltages and where the power is and should be.
              No signal - from a cut wire or faulty sensor - will fault the computer. A bad fuse or relay can disable the computer.
              There may be an internal fault in the computer.
              All of these things will cause the light to come on.
              88 325 IX DiamantSchwarz - TOURING - waiting...
              89 325 IX AlpinWeiß - Gone
              88 325 IX DiamantSchwarz - Parted
              89 325 IX RoyalBlau - Parted
              88 325 IX RoyalBlau - Gone
