Repairing my shortened rear bumper
  • Jand3rson
    • 37587
    Since I've got my car torn apart in all kinds of different ways, I figured it was about time to fix my shortened rear bumper. We did an awesome job on the backside of them, using fiberglass to bond the sections back together, but on the frontside, we didn't use the right method, and the seams cracked through to the paint. We simply filled the gap in the seam with epoxy, and there was nothing really holding the 2 parts together in the front.
    About this time last year, I picked up an AWESOME book:
    So what I did it stripped an area about 2" each direction away from the seams back down to bare plastic, then used an orbital to get the surface level. Then I used an air-tool with a sanding head to grind a v-channel out on top of the seam. I also drilled several small holes along the inside of the channel for the plastic epoxy to settle into, creating more holding strength by kind of stitching the 2 parts together:
    Here's the top of the bumper, where I did the same thing:
    Also did the same for the bumper trim, and this is with the first application of plastic epoxy, I'll probably have to do a little more filling once I get it smoothed out:
  • Holland
    • Nov 2008
    • 7204
    Awesome. looks like fun.
    Originally posted by DEV0 E30
    • Jand3rson
      • 37587
      I really like doing this sort of thing, so I have a good time with it.
      • kamotors
        • Nov 2007
        • 7102
        body work can be fun, I had lots of fun rebuilding my car last year.
        7speedshop.com
        • Holland
          • Nov 2008
          • 7204
          I wasn't sure something like this was even possible.
          • straight6pwr
            • Sep 2004
            • 3450
            did you know you can 'weld' plastic, which is probably the way i would have went for this project. it chemically melts the two pieces of plastic together, essentially creating one piece that is as strong as the original.
            however, this way is very acceptable as well. looking forward to progress! does that book even cover modern plastic welding? circa 1985?
            • Jand3rson
              • 37587
              Yah, I know about plastic welding, I just don't have access to one. I used this for repairing the broken corner of my front bumper, and it worked amazingly well.
              The book does cover modern plastic welding, it's a really awesome book. I would definitely recommend picking it up if you do any kind of plastic work like this.
              • Jand3rson
                • 37587
                Did some more work today, got the plastic epoxy from yesterday sanded down to level.
                Borrowed an orbital sander from Andrew, made short work of taking everything down:
                As you can see from the pics tho, this stuff tends to make some air bubbles as it's drying, so I did a small skim coat over the top of all 4 of the seams to fill them:
                • Jand3rson
                  • 37587
                  Got some more sanding done and realized I'd been taking a lot of actual material out of the surrounding bumper plastic as well, and made some low spots, so I'm going to have to skim some more in there to get it leveled out again. No biggie though, I'd rather use this stuff than Bondo.
                  I fucking hate Bondo.
                  • Jand3rson
                    • 37587
                    Just got finished primering the bumper and trim after finishing up all the repair work. There were still some air bubbles and low spots after the last application of plastic epoxy, so used filler and pot putty to fill and even them out. After that was all fixed, I cleaned the whole surface thoroughly with acetone, then plastic cleaner/prep, then put on 3 light coats of adhesion promoter, and then 4 coats of high build primer.
                    Here's how everything came out after the last coat of primer. See any seams? No, you don't.
                    • straight6pwr
                      • Sep 2004
                      • 3450
                      wow looks very nice! excellent work, and i think you owe 80s book guy a thank you.
                      • evil_twin
                        • Nov 2007
                        • 2965
                        Damn! That looks awesome!
                        Paypal: vdang5@gmail.com
                        Delta Auto Care
                        2875-C Towerview Road
                        Herndon, VA
                        703.435.1375
                        My Feedback Thread: Evil_Twin
                        • Spaz
                          Crazy Canuck
                          • 2276
                          lookin fancy!
                          Cam .W '91 325is
                          Spaz's 1991 Alpine White???? S52 Build Thread...
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            Damn man, that looks good
                            -Andy
                            • ZM Blue Devil
                              • Dec 2006
                              • 13836
                              Excellent, this is very cool. Ive been putting off doing a mt2 rear bumper. Now Im inspired.
                              Levent
                              %20levent@gutenparts.com
                              Ladies:
