Sap!!!!!!!
  • Nosis
    • Nov 2008
    • 19
    Sap!!!!!!!
    Any one know how to take off tree sap safley I already did the clay thing it worked some what any other thoughts ???????
  • Jparkr
    HR Admin
    • Jan 2006
    • 3494
    I use olive oil.
    I just dab my finger in it and then rub the sap, let it soak in for maybe 15 seconds, then start picking it off with your nail. If the sap feels sticky again just put more oil on it.
    The oil prevents the sap from sticking to anything. So in the end you have a little oily sap bugger
    1987 PRO-3 car /1990 325is (2.7i Concours)
    • ProjektONE
      • 20
      Ive used goo gone, clay bar, wax. In that order.
      • StereoInstaller1
        GAS
        • 22679
        Simple hot water will do wonders if the sap isn't too old
        Closing SOON!
        Thanks for 10 years of fun!
        • Jparkr
          HR Admin
          • Jan 2006
          • 3494
          The problem with goo gone is it will remove the wax in the area it was applied.
          The oil removes the sap and is just able to be wiped away.
          • kamotors
            • Nov 2007
            • 7102
            I've only had a little sap stuck to the car but the ice clay bar stuff actually removed it with minimal effort.
            7speedshop.com
            • Jparkr
              HR Admin
              • Jan 2006
              • 3494
              I dont know about liquid ice claybar.
              But i know there "wax" is fucking bullshit.
              basically just smearing grease on your car. lol
              I would recommend never to buy anything along the lines of turtle wax ice.
              • Detlman
                • 68
                rubbing alcohol works wonders for tree sap.
                89 325i
                05 Cooper S/500whp ( for sale )
                • bejbis
                  • Dec 2008
                  • 596
                  +1
                  -Dan
                  • ethree
                    • Aug 2007
                    • 1213
                    It cuts the sap well but it's not good for your clearcoat if you have one.
                    • Cobra Jet
                      • Apr 2008
                      • 278
                      WD40 will remove "new" tree sap. Sometimes it works on removing sap that has sat for a bit (as in weeks), but may not make a dent in sap that's been on the vehicle for months or years... WD40 will not harm the painted or clearcoated surface either. Use a microfiber towel or 100% cotton towel when trying to remove the sap after spraying w/ WD40.
                      • atomic
                        • Jun 2007
                        • 5691
                        Wurth Clean Solve Cleaner
                        It will strip the wax but does wonders on removing stuff like sap without being to harsh on the paint surface. A+ product...
                        • thereisnoyun
                          • Feb 2007
                          • 2301
                          go get some paint cleaner for auto detailing. If you dont have a polisher just use hand application and rub vigorously. Personally, I detail and thats how I remove it with a orbital. Its safe, and its part of the process.
                          As stated before, hot water and soap will do fine if its not too old. If its old its hard not to damage the paint using stuff like paint thinner, wd40 or goo gone.
