Mtech 1 / IS lip mounting template
  • 32.5i
    • Sep 2005
    • 1336
    I've searched and can't find it..
    I'm pretty sure I've seen a link or something on here..
    Anyone have a link or know where to get it?
    Thanks
  • ethree
    • Aug 2007
    • 1213
    Try searching for 'is' spoiler, lip goes on the front or go here:
    • atomic
      • Jun 2007
      • 5691
      I used a 24" x (how ever wide the trunk is from side to side + some extra on each side) wide piece of freezer paper (like what is used in butcher shops to wrap meat with). I taped the paper across the trunk of a e30 that had the oem "is" spoiler taken off of it. I then traced the outside edge of the trunk at each side and the backside under the rear window. Then I marked the location of each hole where the oem "is" spoiler was mounted on that trunk. I then transfered that paper onto my trunk where I taped it off when the 3 lines I traced lined up with the same edges on my trunk, marked the hole locations and used a small punch to keep the drill from walking around and drilled the holes to the correct size.
      Worked like a charm and took maybe 5 minutes to do... Hell with all of that metric measurements in that link.
      • 32.5i
        • Sep 2005
        • 1336
        this ! thanks mate good idea..
