Seam Sealer in Cowl Drains
  • ckrock946
    • Oct 2026
    • 3
    Sorting through some interior water intrusion problems. One of the causes I've tracked down is cracked seam sealer inside the drivers side cowl drain. Anyone have experience solving this issue? Would a simple clean and application of an undercoating (like waxoyl) be a viable solution?
  • max.rodriguezzz
    • Sep 2024
    • 76
    you can also buy/use seam seamer again.
    you dont want water pooling anywhere without a drainage passage
