How to clean inside of Rocker Panels
  • R3VN R3D
    • 247
    My Sunroof Drain is clogged and flooding the floor on the Passenger side. I ran wire down the front drain hole on the passenger side of the Sunroof and it came up caked in mud. How can I get into the space to clean it out? Thanks.
    "Drive like you mean it. Commit."
    "Progress Fervently."
  • R3VN R3D
    • 247
    Wrong Section? Anyone know? Am I correct in thinking that the Sunroof Front Drains drain into to Rocker Panels? That seems like a bad design IMO. And then to have holes for wiring to go through to the Interior. Isn't that were the water comes through to the inside? Through the wiring holes?
    • R3VN R3D
      • 247
      Anyone? Dare I drill a hole into it at the wheel well just behind the front fender? And then protect the new hole with primer and a rubber plug after cleaning out the rocker void?
      • Brian 89 325i
        • 1450
        The most common fix for a clogged sunroof drain is compressed air. Put the little rubber nipple on the air chuck, stick it in the drain hold, and BLOW!
        Should fix your problem. If not.....good luck?
        • mrsleeve
          • Mar 2005
          • 16386
          there is a drain hole just behind the front wheel, take a wire coat hanger and straighten it out and ram it up there and losen all the shit up. The flush with more water or compressed air.
          Originally posted by Fusion
          William Pitt-
          • R3VN R3D
            • 247
            Thanks guys... Sounds like I can temporarily clear the passage ways of all the crap, but all the shit just stays in the Rockers, for ever.... I wish you could access the void to clean the crap out... eventually, so much crap will fill the space that I don't think compressed air and coat hangers will do the trick anymore....
            • learningcurve86
              • May 2008
              • 715
              probably a stupid idea... but what about using a pipit to put draino down it?
              Greg
              • R3VN R3D
                • 247
                Sorry but, whats a pipit?
                • nmlss2006
                  • 910
                  I think he means a pipette http://en.wikipedia.org/wiki/Pipette. I'd be very VERY VERY careful with Draino, though.
                  • R3VN R3D
                    • 247
                    Yeah, Im more concerned with cleaning the void out than with just clearing the passage ways...
                    Although, perhaps he stating that maybe drano would break all the material in there down to nothing, thus cleaning out the void...
                    I still would like to just be able to stick a vacumm hose attachment in there and suck it all out...
                    • nmlss2006
                      • 910
                      I am afraid I do not follow: cleaning the void out?
                      • R3VN R3D
                        • 247
                        Inside the Rocker Panel... Is that not where the Front Sunroof Drains drain into? Or am I mistaken?
                        • guibo09
                          • Dec 2008
                          • 834
                          no you are correct.
                          short of pumping degreaser and a bunch of other chemicals into the rocker panels, not sure what else you can do. my car was rust proofed, so i does have some holes in the door jams for oiling. but i dont know how helpful they can be.
                          90 E30 325i
                          • R3VN R3D
                            • 247
                            Originally posted by guibo09
                            no you are correct.
                            Rust proofed? How's that?
                            • guibo09
                              • Dec 2008
                              • 834
                              ah, its something you will never need to deal with where you live. up here in the rust belt, there's something called anti-rust treatment. they basically shoot the underside of the body and the inside of the body panels with oily or waxy substances to protect from rust in winter. but since the rocker panels are a top target for rust, they drill a couple of 1/2" holes in the door jambs and spray some oil in there.
                              90 E30 325i
