84 325e rear emblem
  • csp713
    • 25
    84 325e rear emblem
    Anyone know where i can find a pristine rear trunk emblem for a 1984 325e? also, how would one install and take off/shave the emblem?
  • BTP325ic
    • Apr 2009
    • 700
    Book cheap international flights with confidence. Bmpd's AI predicts delays and cancellations so you can choose the most reliable and affordable flights.
    • BTP325ic
      • Apr 2009
      • 700
      not sure about the shave trunk thing but try those sites for the emblem,this reminds me i need a new rear emblem myself.
      • John in VA
        • Aug 2007
        • 553
        The "325e" is just stuck on. You can remove it with dental floss and a little WD-40, gently sawing off the numbers & letters.
        The BMW emblem (roundel) is held on with 2 pegs, at 3:00 & 9:00. You can protect the paint with a old credit card or cloth and gently pry it up with a screwdriver. There are 2 grommets in the holes to hold it securely. You would need to do some body work & paint to make it look decent if you want to remove it permanently.
        • csp713
          • 25
          thank yall. helped tons.
