how to remove rear pop out window
  • Poopie
    • 295
    I'm stripping the car down a bit to paint and I can't figure out how to get the rear window out. Do I have to remove the b pillar trim from the outside?
    also, how you I remove that trim that goes over the door seal? Its the metal one that protects the seal. Thanks
  • Jean
    • 18228
    No, from the inside. Then you'll see two nuts that hold it.
    • M-technik-3
      • 18946
      two 8mm behind the B pillar and the nut on the window bracket. Takes maybe 15 minutes.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        • Poopie
          • 295
          got it, thanks. i noticed there was some play in the window and trim, figured you might be able to slide it out. Thanks for the tips guys
