i think you should make a signature with a paypal DONATE button. everybody here, and elsewhere on the web, OWES you bigtime. i can't begin to tell you how much i have learned from this thread and how many 'mysteries' you have unveiled.
you don't just do a good job on your work, you are an excellent teacher as well. one place you succeed where all the other manuals fail is avoiding the "reassembly is the reverse of removal" easy way out. that's huge. seriously. i will refer to this thread for nearly any major repair going forward. FIRST. if for nothing else just to get my head straight!
i actually had the 'pleasure' of painting part of MY car. it was a nightmare. after reading your writeup, i think.....well...it would still be a nightmare, but i would feel a lot more comfortable. i don't think people realize how much time you spent prepping that car. prepping your area. sanding without exposing bare metal. feathering edges properly. making the body creases perfectly straight. cleaning and sanding every crevice of that airdam. EXCRUCIATING work, but simply amazing. oh yeah, and then a little tranny rebuild for dessert. good gawd.
i haven't posted to R3v in years i don't think. but i couldn't let this pass me by without expressing my gratitude. thanks from me and everyone else who has ever loved an S14, M20, M30, E30, E28 or any of the myriad early BMW's to which all of these lessons apply.
Well, it's taken what feels like an absolute eternity to get to this stage of the build,
but, finally, the engine is ready to be reunited with the chassis........
there was a few little things to take care of before the engine could be lowered
into the bay. Once the engine was off the stand the flywheel and clutch needed
to be refitted. In keeping with the theme of the rest of the engine build I've gone
with a lightweight flywheel. The flywheel weighs in at 5.3kg and is supplied by http://www.ttvracing.com/BMWS14flywheel.html.......
With the flywheel in place the clutch could then be fitted. The clutch was
only fitted to the car shortly before it came off the road for this little make over,
and as a result has very little mileage on it and is good to go again......
The clutch disc is sandwiched into place by the pressure plate which is
bolted on by six little bolts, shown below........
the important bit being to make sure the splines in the centre of the clutch disc
line up with that little spigot bearing in the centre of the crankshaft..........
as when you go to throw in the gearbox later on, the splines on the
input shaft (red arrow) need to slot into the splines on the clutch disc,
and the little piece on the end of the input shaft (yellow arrow) needs
to slot home into the centre of the crank spigot bearing..........
So you can see it's worth spending a few minutes now to make sure the clutch
disc is lined up correctly, rather than busting a ball later trying to fit the gearbox into
place when things don't line up. If you find yourself in the same position I do,
with both engine and gearbox out of the car, it can make sense to mate the two
of them together outside of the car briefly just to make sure things line up.
With the clutch fitted the final item to go on before the engine is lowered into place
is the gearbox bellhousing.......
(picture borrowed from google images)
As the bellhousing is detachable from the getrag gearbox it can be a lot handier
fitting this to the engine now while it's out of the car, and then when everythings
back in the car you've 4 nice studs sitting out the back of the bellhousing to
lift the gearbox onto, rather than fumbling around trying to get bellhousing to
engine bolts started.
With all the soundproofing and heat sheilds fitted to the engine bay the
way was now clear to shove it back in.....
And then with a wave of the magic wand and quite a bit of foul language
the engine and gearbox magically find their way home.........
How many people will die when this car gets its first scratch, rock chip, or ding?
he said earlier in the thread that he doesn't care because he's still going to drive the car like it's supposed to be instead of garaging it for the rest of its life.
My friend this is an unbelievable thread. If i was the CEO of BMW M Division i would call you for the first ride officially in Germany.Thank you for all the details of the rebuilding.
Was asked the same question on another forum a
short while ago and the answer is when it's done,
it's going into a carcoon humidified cover and carefully
parked up in the garage so it'll keep it's future value
as a collectors item hopefully. I may take it out for
some car shows, but only during the summer months
when the weather is sunny. Might drive it to the odd
show instead of trailering it all the time to keep things
from seizing up, but it would be heart breaking to get
any stone chips on it.
BOLL*CKS TO THAT CARRY ON,
I plan on driving the door handles off it 7 days a week
till fossil fuels run out. There's no way I could put this
much effort into a car only to keep it "garage queened" for the
next owner to enjoy. Sure it'll get stone chipped and scratched
as time goes on, but I guarantee you I'll enjoy every mile while
collecting them.
If people keep quoting me in their sig, I'm going to burn this motherfucker down.
With the engine now back in place focus could turn to some of the item's that
would need relocation thanks to the bulky addition of that new airbox.
First on the list was the brake fluid reservoir..........
With the new airbox proudly now sitting in the space where the old reservoir
pictured above used to be, a plan needed to be hatched.
Common wisdom suggests that a good sized hammer can almost always make
two objects occupy the same space at the same time, however, since the airbox
"kit" I had purchased came with the bits to relocate reservoir, I decided to
save the hammer approach as "Plan B".
Below is a picture of the reservoir that came with the kit.......
theres absolutely nothing wrong with it and I'm sure it works fine, for reasons
still unknown to me I decided to endure a lot more hardship to make the
reservoir below work instead.........
The one slightly large difference between the two reservoirs above is the
"kit" one has the required 3 outlets (2 x brake master cylinder feeds, 1 x clutch master
cylinder feed) and the one I had decided to use had a big, useless, threaded lump
of an outlet.
So, the threaded fitting was removed for the reservoir and an hours worth of beating,
drilling and brazing had it looking a bit more functional........
After which it was a simple matter of fitting the two supplied elbows to
the master cylinder.......
and then connecting everything up with the correct spec. hose.......
What the above picture doesn't show to well is the feed from the reservoir
down to the clutch master cylinder, which travels down behind the brake servo.
I had actually taken a separate picture of this, but, due to my continuing startling
incompetence with a camera, it came out pitch black.
Gifted.
One thing probably worth mentioning before we move on is about the
hose used to carry the brake fluid. I can't remember the part number for the
Gates hosing used here,( it's late and if I go searching the net for it I'll just get
distracted by porn sites or cheap shiney shite on e-bay), but if you find yourself
doing a similar job it's worth spending a few minutes checking the manufacturers
website to see if it's compatible with the type of brake fluid you intend to use.
Some hoses have difficulty containing synthetic brake fluid and will slowly weep
it all out over your nice clean engine bay. Which is fun.
With the reservoir plumbed up all that was left was the small matter of mounting
it somewhere. Small bit of stainless steel cut and bent to the correct shape..........
and a few holes drilled and taped into the underside of the strut brace......
Next on the list of things needing to find a new home was the power steering reservoir.
Like all e30's it's normally bolted to the turret, however with the addition of the new
airbox this is no longer possible.
The new site was to be a little lower down on the front inner valence using these two
original studs for mounting............
the original reservoir mounting bracket needed a little modifying before it was
good to go again. With the spot welds drilled the mounting part could be removed
and tossed........
to be replaced with this instead........
once welded on the bracket was bolted up to check I hadn't welded it arseways,
which seems to happen with alarming regularity.......
all good, so a quick lick of paint........
and nail her on for good..........
There was one other slight mod done to the steering system and it was
carried out a while back when the driveline was going in and that was
to change the steering rack.
If your the kind of person that likes to let the car steer from the rear every
now and then, more than likely you'll have noticed how slow the steering
is on e30's. A fairly common "upgrade" is to fit a quicker ratio steering rack
from some of the more modern BMW's and this is what I've chosen to do.
However, sourcing the correct left hand drive rack in a country full of right
hand drive cars proved fairly challenging. Thankfully a good friend came to
the rescue with what you see below, a reconditioned E46 compact steering rack,
I think.......
the reason I say "I think" is because there's no BMW or ZF identification numbers left on
the rack after it was reconditioned. Nothing too suspicious in this, I've bought a few
reconed racks in the past from TRW and they were all the same.
However it does leave you with a little bit of a conundrum. How do you know if
this rack is going to be any faster than the one already in the car?
The answer is fairly straight forward, measure the movement.
With the rack on the bench like below one of the dust boots is removed
from either side and then by turning the input shaft lock the steering all the way to
one side.
Then, turn the input shaft exactly 1 complete turn in the opposite direction and
measure how much the rack moves.........
The standard steering rack in an e30 M3 moves the rack 38mm for one
complete turn of the input shaft. So any more than this is going to give you
a quicker steering rack. As you can see above this rack moves 50mm for
one turn which is quite a bit "quicker" than the old one.
The only other rack I've ever had the chance to measure was the rack
from a Z3 BMW which is a popular choice, and it measured 53mm,
which I think maybe the quickest BMW rack that will fit an e30.
So, happy that the rack I had was going to quicken up the steering response
the next job was to get it ready to bolt in. The first thing that needed to be done
was to swap out the inner track rod arms, as the ones that came fitted to the new
rack where the male threaded variety, whereas I wanted to retain the e30's
female threaded ones............
The ball joints of my original inner track rods were still in perfect
nick so a quick clean up, a lick of paint and some fresh grease in on
the ball joints and they were ready to go again.........
When these inner track rods were fitted to the e30 steering rack they
had a little washer with two bendable tabs to prevent them ever unscrewing,
however these washers aren't compatible with the new rack, so instead
they're getting a dab of loctite to keep them secure........
The last things that were needed to complete the rack were the outer track rods ends.
The balljoints on the old ones were showing signs of wear so a fresh pair took
their place..........
With everything buttoned up the rack was now ready to bolt into the subframe.......
To do this requires a pair of little spacers as the mounting tabs on the new rack
come up a little short between the mounting lugs that hold it on the subframe.........
for now a little pair of spacers 13.5mm high were made up to go between the
top of the rack mounts and under the subframe lug as shown by the arrow above.
The height and number of spacers may change a little down the line when we get around
to measuring front suspension bump steer, but for today those 13.5mm one's will do fine.
Final piece of the jigsaw is the steering shaft. The original was cleaned up,
fitted with a new rubber guibo and is good to go again with no noticeable
wear in the joints........
the splines at either end get a wee dab of grease so you don't need to
swing the hammer quite as far when battering them into place.......
