E30 clear coat--how soft?
  • stevehecht
    • May 2007
    • 38
    I have been going on the assumption that the older the car the softer the clear coat. Only because the new bimmers have hard ceramic-based coats. Just how soft ARE our clear coats? It makes a difference when choosing which polish to use on the car. For instance the Menzerna are supposed to be designed for the ceramic based coats while a product like Optimum Finish Polish is indicated for older, softer paints. (They are both light polishes.)
    1990 Schwarz 325i coupe
  • StereoInstaller1
    GAS
    • 22679
    Most E30 colors are single stage.
    Closing SOON!
    Thanks for 10 years of fun!
    • John in VA
      • Aug 2007
      • 553
      If your clear-coat hasn't already flaked, crazed or peeled, I would categorize the original as fragile or hard after 20+ years. Be careful!
      • TrentW
        • 2815
        Only the metallic colors are clear coated from the factory.
        • stevehecht
          • May 2007
          • 38
          hey John...fancy meeting you here. So stick with mild/medium cut polishes and no yellow pads. I've used an orange pad with a medium cut polish and it worked out OK. But I will be careful. Didn't know the paint is single stage.
          • StereoInstaller1
            GAS
            • 22679
            Pretty much all, but the metallic colors are base/clear
            Closing SOON!
