rear valance
  • e30loverSC
    • 575
    rear valance
    Next week ill be buying a pre fabricated plastic bumper swap for my 87 is. It comes with a rear valance. And im wondering how they go. Whats the best way? Do they bolt up or what.?
  • xwill112x
    • Jan 2009
    • 4236
    the oem rear valence will have to be welded on.
    • e30loverSC
      • 575
      ok, thats not to bad.. But are there any kinds that i can bolt up? That arent too bulky and look funny? ANy pics would be a big help
      • xwill112x
        • Jan 2009
        • 4236
        what do you mean by any kinds?
        this thread may help as well..
        • e30loverSC
          • 575
          Thanks has anyone ever welded an OEM apron in the back??
          • blazing
            • 274
            He did a nice write up check it.http://www.r3vlimited.com/board/show...er+swap&page=6
            • e30loverSC
              • 575
              Ok thanks. Will be starting this project very soon!!
              • td325ic
                • Feb 2006
                • 785
                While if you want to be thorough you can weld on a late-model valance like Josh Anderson did in his Project Facelift thread. He did an excellent job, but it should be noted that welding is not the only way to do it.
                Nuts and bolts, body screws or stainless steel pop rivets will all work well for attaching the apron securely. You just have to seal everything well afterward.
                Once you trim the excess metal from the apron then you'll find the mounting part pretty easy, but you'll definitely want a second person to help. Just follow Josh's thread and examine the pictures, everything you need to know is in there.
                • e30loverSC
                  • 575
                  Ok. Thanks A lot! I will definitely be doing this! One way or another. I might use nuts and bolts. :)
                  • e30loverSC
                    • 575
                    Well ok im might drill a hole every few inches and put some oxide coated bolts with washers in and lock nut or something. Then get some sort of sealer not sure what kind yet. ,, and paint over all exposed metal then take all bumpers to a paint shop and get then painted!! and put everything on!! that should do it!! I can wait!! And then im gonna put a different lip on!!
                    • ck_taft325is
                      • Sep 2007
                      • 6880
                      Post some pictures of the results. Some guys will tell you that it's not the smartest to put any holes in your body, but if you seal it well and give it a few coats of paint, it shouldn't see much wear and tear. Be sure to primer AND paint it though. I'd even clear it over the paint just to make sure ;)
                      Need a part? PM me.
                      • e30loverSC
                        • 575
                        Ok if I go that route I'll seal the he'll ot of it. I'll do it anyways probably. If I can get my hands on a welder near by I'll so it that way.
                        • StereoInstaller1
                          GAS
                          • 22679
                          WTF, why do you guys act like no one has ever made a hole in goddamn sheetmetal...you would do just fine using a top quality auto body adhesive and sheetmetal screws.
                          Remember, if metal is covered by ANYTHING that isn't porous, it wont rust.
                          The ONLY reason a car (or anything else) rusts is that the paint has failed somehow.
                          So go ahead and bolt that thing on, glue it properly in place and spray some paint on it. It will work great and last for years!
                          Luke
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • e30loverSC
                            • 575
                            Ok thanks for the input! I will do
                            • thedeal
                              • 643
                              Originally posted by stereoinstaller1
                              wtf, why do you guys act like no one has ever made a hole in goddamn sheetmetal...you would do just fine using a top quality auto body adhesive and sheetmetal screws.
                              Remember, if metal is covered by anything that isn't porous, it wont rust.
                              The only reason a car (or anything else) rusts is that the paint has failed somehow.
                              Luke
