Repairing some dings: is white easy to match?
  • mach schnell
    • Apr 2008
    • 1059
    I want to have some dings repaired. They are the dimpled kind, that come from someone else's door, for example.
    Are these difficult to repair?
    And is alpine white easy to match? My car is a very clean and bright cool white...
    ... I do NOT want to have big cream-colored spots in my clean white paint.
  • koole30
    • Jan 2010
    • 28
    There are variations of every color from factory paint (painted at different locations, different paint vendors etc...) To be safe blend into the nearest panel to trick the eye, this is whats done at most high end shops. PM me with any questions.
    Good luck.
    • mach schnell
      • Apr 2008
      • 1059
      Good luck.
      Thanks!
      I am not going to do the work myself, I am going to take it to a shop in the local area.
      But are these dimples pretty simple to repair?
      And is white easy or difficult to color-match?
      • scottinAZ
        • Dec 2009
        • 1312
        a good shop should be able to color match the panel fairly well. the dents are not that difficult, so much as time consuming to repair. If you want to do it right, you need to access the back of the panel and try to push it out as much as possible, and use the least amount of filler. this is where the labor adds up on a job such as this.
        I saved 15% on my Bimmer parts by switching to ...
        • mach schnell
          • Apr 2008
          • 1059
          Great, thank you!
