Removing painted-on pinstripe with a Dremel
  • Jand3rson
    • 37587
    A WHAT??? That's right, a Dremel. I did it today, and it works! Thanks to Parker for hooking me up with this video:
    Do what the man says, BE CAREFUL and do not apply too much pressure! I found that going at a few different angles can really help with stubborn areas, but never with too much pressure against the tool. Also, you will go through several of the felt heads, I went through a pack of 6 just doing my 2 doors and one fender.
  • AndrewBird
    The Mad Scientist
    • 11898
    Pretty cool.
    • e34john
      • Apr 2006
      • 3599
      Does that work better than those rubber eraser wheels?
      • Jparkr
        HR Admin
        • Jan 2006
        • 3494
        This will only work for adhesive pin striping, not painted on.
        1987 PRO-3 car /1990 325is (2.7i Concours)
        • fiftytakedowns
          • 2460
          thanks Ill use that!
          [/url]
          Team USA Wrestling 67KG
          • Jand3rson
            • 37587
            That's what I used for the stick-on stuff. But under that on both my doors and the pass. fender, it was painted-on.
