IS Trunk Spoiler Nut is Stuck
  • hamann318is
    • 3382
    I've been trying to remove my rear spoiler, but I'm afraid I tightened the two side nuts too much after taking it off last time. So now I use a 10mm nut-driver which grabs on fine. However, when I try to turn the side nuts, the driver just rotates over the end nuts and nothing happens.
    Is there anything I can do to get these off?
    The BMW 318 is back. With a vengeance.
  • DanGillan
    • Mar 2004
    • 4061
    you need a deeper nut driver, the bolt is hitting the inside back of the nut driver before it the 6 point (or 12) reaches the nut. get a deeper one.
    Dan
    • hamann318is
      • 3382
      I'm pretty sure it goes all the way on...
      • DanGillan
        • Mar 2004
        • 4061
        then i guess im wrong, are you sure your using the right size? (8or 10mm i believe)
        Dan
        • hamann318is
          • 3382
          10mm, I've tried forcing a 9mm on, but doesn't work.
          • m42technic
            • 1056
            Doesit still have the stock plastic nut? Just cut it off.
            James Peacock
            WWFSMD?
            • hamann318is
              • 3382
              I def want to goto metal, but how would you do that, there's not that much room. Drimmell?
              • bmwm3n528
                • 3654
                Dremel or get a hammer and a large nail-like object, and start hacking.
                Dremel would probably work best though :D
                Trevor Ely
                '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                • ToplessE30
                  • 4791
                  Dremmel the shit and get metal ones. The plastic ones are pointless anyways. Good luck with your decision.
                  Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                  • thejimlab
                    • Oct 2004
                    • 588
                    hammer a standard size socket onto that fugger
                    • Hubbert
                      • Oct 2004
                      • 67
                      before butching it , try taking a 9mm socket that you don't care about, cherry it up with a propane torch and melt it on, don't try to losen till it cools, hope this helps! .
