Front Valence texture?
  • Bmw e30 Justin
    • 316
    So when you order a new valence it comes primed and not textured or rubber coated (rolling off the showroom they were textured)..... How are you guys coating it and in what product. I want to maintain the factory look but I'm having problems finding what to use.
    Thanks
    Justin
  • Jand3rson
    • 37587
    If you really MUST undercoat it, I would go with 3M or DupliColor, they both make a very good product. But I would leave it smooth, looks SO much better. I detextured mine before I installed it when I did my facelift.
    • metalsoul
      • 871
      +1 on smooth, I hate that they're textured from the factory
      BUY YOUR KLUB VINTAGE WINDOW DECALS!
      http://www.r3vlimited.com/board/showthread.php?t=265552
      Klub Vintage - Classic and specialty car builds and restorations
      http://www.klubvintage.com
      Located in Lambertville NJ
      • THE FEZMAN
        • Jun 2010
        • 89
        textureing is an art, i would keep it smooth. but if you must texture it 3m makes several products that will texture it, just do your self a favor and practice a lot before trying the final product if you screw it up its a pain in the ass to fix
        • 619E30
          • 1753
          Sorry to get off topic, but how do you remove the texture?
          Originally posted by audiquattrot
          bimmers b4 b*tches....remember that.
          1990 Alpinweiss 325i - secret 500whp build
          2000 Audi S4 B5 Laser Red
          1990 Nissan 240sx - Drift Missile
          2006 CBR600RR
          • kamotors
            • Nov 2007
            • 7102
            keep it smooth
            7speedshop.com
            • THE FEZMAN
              • Jun 2010
              • 89
              sand the hell out of it till its smooth then prime it with a 2k high build primer then sand the hell out of it some more
              • Jand3rson
                • 37587
                Yeah, have fun with that.
                Or you can just remove it completely. If I had to do it again, I would have it sandblasted, but I did it with a Makita grinder and a wire wheel.
                • THE FEZMAN
                  • Jun 2010
                  • 89
                  i try to avoid sand blasting, not only is it a mess it can cause more damage than is necessary, soda blasting is supposed to be the hot lick now, but since i dont have a soda blaster and i dont pay for sand paper.... i just sand everything now if it wont fit in my bead blaster
                  • Jand3rson
                    • 37587
                    More damage than necessary? You'll have to explain that one to me, it's sheet metal.
                    I had my driver side fender sandblasted at a shop after an accident for $25, took it to the body shop for primer and paint, and got it back in better shape than it was before.
                    • Spaz
                      Crazy Canuck
                      • 2276
                      I recommend it smooth as well. I'm looking for pics of the rear done smooth tho hmm
                      Cam .W '91 325is
                      Spaz's 1991 Alpine White???? S52 Build Thread...
                      • THE FEZMAN
                        • Jun 2010
                        • 89
                        i was going to do a photo essay on the damage caused buy sand blasting sheet metal but i got busy today at work. the short of it is that "media blasting" ie, plastic media, walnut shells or soda blasting is perfectly acceptable for large area stripping. sand, aluminum oxide, glass or garnet is not, they are way way too abrasive to be used on sheet metal.
                        when using sand or an other "hard" media the metal shrinks and warps also there is a coating that is part of the makeup of the metal that is damaged that can not be replicated buy the aftermarket. any piece of the part that is folded over like a door edge or if there is any spot welded bracket, basically anywhere there is a joint that can not be accessed, sand or what ever other hard media gets behind that joint and will cause rust.
                        sand blasting is acceptable for small spots of rust or pitting that can not be cleaned any other way but i avoid sand at all costs and when im forced to do it i try to tread as lightly as possible
                        since im new here i guess i should say that ive been a professional auto body painter and sheet metal fabricator for over twenty years. i am not a hobbyist.... and im a little nutty.... to many paint fumes. :mrgreen:
                        but this was a hard learned lesson for me, back in the late 80's and early 90's i did a lot of de lamination overalls on ford trucks, the shop that i worked for thought it would be a great idea to sand blast the trucks instead of using plastic media because it was considerably cheaper ..... needless to say i spent about 50+ hours blocking out the first one to get half of the waves out of it... ford was only paying 20, we took a bath on several of them before they wised up to what was going on, i also had a customer decide to sand blast his 66 mustang..... he basically ruined the entire car and i ended up having to coat the entire thing in body filler to fair the surface for paint.
                        • raafhimself
                          • Dec 2008
                          • 451
                          valence 1.0 i removed the texture, i used a wire bristle attachment on a drill-- took forever. on the rear valence i ended up using aircraft grade paint stripper, easiest method of all. i ultimately had it re textured (i believe it was wurth stone guard), the asshats who sprayed my front valence used no primer (i gave them bare metal), started to rust up quick.
                          long story short-- i prefer the aesthetics on the smooth, but dealing with that first rock chip will hurt your soul. stone gaurd FTW.
                          • ak-
                            • 12422
                            1991 325iS turbo
                            • dnova89
                              • Aug 2009
                              • 851
                              Originally posted by ak-
                              sexy sex mclovin baby!
                              -Darius (aka DiscoDoughnuts on other forums)
                              dude man bro...
